Ana içeriğe geç
ASUS Transformer Book Flip TP500LA RAM Replacement
Neye ihtiyacın var
    1. ASUS Transformer Book Flip TP500LA RAM Replacement, RAM: adım 1, 3 resimden 1. ASUS Transformer Book Flip TP500LA RAM Replacement, RAM: adım 1, 3 resimden 2. ASUS Transformer Book Flip TP500LA RAM Replacement, RAM: adım 1, 3 resimden 3.
      • Remove the ten 10 mm Phillips #0 screws found on the computer's back case.
      FixBot'a Sor
      Yorum Ekle
    2. ASUS Transformer Book Flip TP500LA RAM Replacement: adım 2, 2 resimden 1. ASUS Transformer Book Flip TP500LA RAM Replacement: adım 2, 2 resimden 2.
      Bu adımda kullanılan alet:
      Heavy-Duty Spudger
      • 'Slide a heavy-duty spudger in between the back case and the computer.
      • Slowly work around the edges to undo the clips to fully separate the back case from the computer.
      • Gently lift off the back case.
      FixBot'a Sor
      Yorum Ekle
    3. ASUS Transformer Book Flip TP500LA RAM Replacement: adım 3, 2 resimden 1. ASUS Transformer Book Flip TP500LA RAM Replacement: adım 3, 2 resimden 2.
      • Grasp the edges of the RAM case with your fingers.
      • Slowly lift the case upwards to remove the RAM case.
      FixBot'a Sor
      Yorum Ekle
    4. ASUS Transformer Book Flip TP500LA RAM Replacement: adım 4, 3 resimden 1. ASUS Transformer Book Flip TP500LA RAM Replacement: adım 4, 3 resimden 2. ASUS Transformer Book Flip TP500LA RAM Replacement: adım 4, 3 resimden 3.
      • Loosen the RAM's fastener clips by lifting one of the clips as you grasp the RAM card.
      • Carefully lift it away from the motherboard.
      FixBot'a Sor
      Yorum Ekle
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
Solomon Dovinh
435 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S13-G5, Forte Spring 2017 Cal Poly, Team S13-G5, Forte Spring 2017 üyesi
CPSU-FORTE-S17S13G5
3 Üyeler
28 adet Kılavuz yazıldı
1Rehber Yorum
Thank you very much, easy to understand instruction. Where could I buy the parts like the RAM?
Marc LeBouthillier - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 37
Her zaman: 3,195
