Giriş
RAM, or Random Access Memory is used by your computer to store frequently accessed or used information. Your computer then draws upon this storage when you perform an action that your computer recognizes as regular or normal. Having an insufficient amount of RAM can cause your computer to slow down. In this guide we will teach you how to disassemble your ASUS Transformer Book Flip TP500LA and to locate and remove your computer's RAM chip.
Neye ihtiyacın var
'Slide a heavy-duty spudger in between the back case and the computer.
Slowly work around the edges to undo the clips to fully separate the back case from the computer.
Gently lift off the back case.
8 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
Thank you very much, easy to understand instruction. Where could I buy the parts like the RAM?
