Ana içeriğe geç
ASUS U52F-BBG6 Wi-Fi Chip Replacement
Neye ihtiyacın var
  1. ASUS U52F-BBG6 Wi-Fi Chip Replacement, Back Cover: adım 1, 2 resimden 1. ASUS U52F-BBG6 Wi-Fi Chip Replacement, Back Cover: adım 1, 2 resimden 2.
    • Flip the laptop over to the back.
    • Slide the right latch to unlock, then simultaneously slide the left latch outward while pulling the battery out.
  2. ASUS U52F-BBG6 Wi-Fi Chip Replacement: adım 2, 3 resimden 1. ASUS U52F-BBG6 Wi-Fi Chip Replacement: adım 2, 3 resimden 2. ASUS U52F-BBG6 Wi-Fi Chip Replacement: adım 2, 3 resimden 3.
    • Unscrew all twelve 3mm Phillips screws with the J1 screwdriver.
    • Unscrew two 3mm Phillips screws on the black panel using the PH0 screwdriver.
    • Lift the black panel upward by inserting your fingernail in the space provided.
  3. ASUS U52F-BBG6 Wi-Fi Chip Replacement: adım 3, 3 resimden 1. ASUS U52F-BBG6 Wi-Fi Chip Replacement: adım 3, 3 resimden 2. ASUS U52F-BBG6 Wi-Fi Chip Replacement: adım 3, 3 resimden 3.
    • In the RAM and hard drive compartment, unscrew the four 3mm Phillips screws using the J1 screwdriver.
    • Gently pull out the hard drive.
  4. ASUS U52F-BBG6 Wi-Fi Chip Replacement: adım 4, 2 resimden 1. ASUS U52F-BBG6 Wi-Fi Chip Replacement: adım 4, 2 resimden 2.
    • Unscrew six 3mm Phillips screws in the RAM and hard drive compartment with the J1 screwdriver.
  5. ASUS U52F-BBG6 Wi-Fi Chip Replacement: adım 5, 1 resimden 1.
    • Pull the CD drive outward with your left hand.
  6. ASUS U52F-BBG6 Wi-Fi Chip Replacement: adım 6, 2 resimden 1. ASUS U52F-BBG6 Wi-Fi Chip Replacement: adım 6, 2 resimden 2.
    • Insert and gently twist the flat metal spudger between the keyboard assembly and the bottom plastic cover so that a small seam is opened.
    • Put in the metal spudger in the seam to hold its place while twisting and levering the flat metal spudger along the whole keyboard.
    • Be careful not to hit any of the internals with the metal spudger. The regular black nylon spudger should be used whenever possible, especially around batteries or sensitive internal components.
    • You will need add a lot of pressure to open the laptop. Expect to hear snaps as the clips holding the two pieces are released.
    • Slowly pry off the back
  7. ASUS U52F-BBG6 Wi-Fi Chip Replacement, Keyboard: adım 7, 2 resimden 1. ASUS U52F-BBG6 Wi-Fi Chip Replacement, Keyboard: adım 7, 2 resimden 2.
    • Unlatch the clip attaching the white flattened flexible cord with a blue tip to the circuit board with your thumb.
    • Pull out the white flattened cord.
  8. ASUS U52F-BBG6 Wi-Fi Chip Replacement: adım 8, 1 resimden 1.
    • Pull back yellow tape attaching the metal colored flexible flattened cord to the circuit board.
    • Lift up the latch at the end of the cord.
    • Pull out the cord to release the keyboard.
  9. ASUS U52F-BBG6 Wi-Fi Chip Replacement, Wi-fi Chip: adım 9, 1 resimden 1.
    • Find the Wi-Fi chip circuit board, which has a white sticker on it and is connected to a black and white wire.
  10. ASUS U52F-BBG6 Wi-Fi Chip Replacement: adım 10, 2 resimden 1. ASUS U52F-BBG6 Wi-Fi Chip Replacement: adım 10, 2 resimden 2.
    • Unscrew the two 3mm Phillips screws using a J1 screwdriver to release the Wi-Fi chip.
  11. ASUS U52F-BBG6 Wi-Fi Chip Replacement: adım 11, 2 resimden 1. ASUS U52F-BBG6 Wi-Fi Chip Replacement: adım 11, 2 resimden 2.
    • Pull out the Wi-Fi chip
  12. ASUS U52F-BBG6 Wi-Fi Chip Replacement: adım 12, 1 resimden 1.
    • Pull off both wires from the chip.
    • It's advised to label the wires to remember where each colored wire connects to on the circuit board.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ashley DeHuff
852 İtibar
8 adet Kılavuz yazıldı
Ekip
CSU Fullerton, Team 1-3, Bruce Fall 2016 CSU Fullerton, Team 1-3, Bruce Fall 2016 üyesi
CSUF-BRUCE-F16S1G3
4 Üyeler
9 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 9
Her zaman: 473
