Ana içeriğe geç
ASUS U57A-BBL4 Display Assembly Replacement
Neye ihtiyacın var
  1. ASUS U57A-BBL4 Display Assembly Replacement, Display Assembly: adım 1, 2 resimden 1. ASUS U57A-BBL4 Display Assembly Replacement, Display Assembly: adım 1, 2 resimden 2.
    • Carefully pry the two rubber covers at the bottom of the screen off with a metal sprudger.
  2. ASUS U57A-BBL4 Display Assembly Replacement: adım 2, 1 resimden 1.
    • Remove the two 1.84 mm Phillips head screws at the bottom of the screen using PH00 screw driver.
  3. ASUS U57A-BBL4 Display Assembly Replacement: adım 3, 1 resimden 1.
    • Starting from one of the corners, use your fingers to pry the bezel from the screen.
    • There is a popping sound when the bezel is loosened from the screen.
  4. ASUS U57A-BBL4 Display Assembly Replacement: adım 4, 3 resimden 1. ASUS U57A-BBL4 Display Assembly Replacement: adım 4, 3 resimden 2. ASUS U57A-BBL4 Display Assembly Replacement: adım 4, 3 resimden 3.
    • Remove the top two 2 mm Phillips head screws.
    • Remove the four 2 mm Phillips head screws on the bottom.
    • Remove the eight 2 mm Phillips head screws on the sides of the screen. There are four on each side.
    • There are 14 screws in total: two on the top, four on the bottom, and four on each side. Use PH00 screw-driver for removing all 14 screws.
  5. ASUS U57A-BBL4 Display Assembly Replacement: adım 5, 2 resimden 1. ASUS U57A-BBL4 Display Assembly Replacement: adım 5, 2 resimden 2.
    • Don't tear off the bottom of the screen or you might damage the connector cable.
    • Carefully lower the screen from the casing with your fingers, making sure to keep the bottom intact and lay it face down on the keyboard.
  6. ASUS U57A-BBL4 Display Assembly Replacement: adım 6, 2 resimden 1. ASUS U57A-BBL4 Display Assembly Replacement: adım 6, 2 resimden 2.
    • Disconnect the connector cable at the bottom by loosening the adhesive tape and lifting up.
    • Gently slide the cable out of the ridges to free the screen from the casing.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Isabella Bernardi
671 İtibar
6 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S2-G4, Julie Fall 2017 UMass Dartmouth, Team S2-G4, Julie Fall 2017 üyesi
UMASSD-JULIE-F17S2G4
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 274
