Ana içeriğe geç
ASUS U57A-BBL4 Front Panel Assembly Replacement
Neye ihtiyacın var
  1. ASUS U57A-BBL4 Front Panel Assembly Replacement, Battery: adım 1, 1 resimden 1.
    • Make sure the laptop is completely shut down to avoid data complications.
    • Hold the left lock switch towards the left to the unlock option.
  2. ASUS U57A-BBL4 Front Panel Assembly Replacement: adım 2, 1 resimden 1.
    • Toggle the right lock switch to the unlock option.
  3. ASUS U57A-BBL4 Front Panel Assembly Replacement: adım 3, 1 resimden 1.
    • Gently slide the battery out while still holding the left unlock switch.
  4. ASUS U57A-BBL4 Front Panel Assembly Replacement, Front Panel Assembly: adım 4, 2 resimden 1. ASUS U57A-BBL4 Front Panel Assembly Replacement, Front Panel Assembly: adım 4, 2 resimden 2.
    • Remove the two 2 mm Phillips head screws on each side on the bottom using PH00 screw driver.
    • Remove the one 2 mm screw underneath the black cover in the middle using the same screw driver.
  5. ASUS U57A-BBL4 Front Panel Assembly Replacement: adım 5, 1 resimden 1.
    • Remove the RAM by lifting up with your fingers and sliding it out towards you.
  6. ASUS U57A-BBL4 Front Panel Assembly Replacement: adım 6, 1 resimden 1.
    • Remove the three 2 mm Phillips head screws on the hard drive using PH00 screw driver.
    • Remove the remaining seven 1.8 mm Phillips head screws using the same screw driver.
  7. ASUS U57A-BBL4 Front Panel Assembly Replacement: adım 7, 2 resimden 1. ASUS U57A-BBL4 Front Panel Assembly Replacement: adım 7, 2 resimden 2.
    • Remove the hard drive by sliding it to the left and lifting up.
  8. ASUS U57A-BBL4 Front Panel Assembly Replacement: adım 8, 2 resimden 1. ASUS U57A-BBL4 Front Panel Assembly Replacement: adım 8, 2 resimden 2.
    • Remove the six 2 mm Phillips head screws on the top edge of the laptop using PH00 screw driver.
    • Flip the laptop right-side up and open the screen.
  9. ASUS U57A-BBL4 Front Panel Assembly Replacement: adım 9, 3 resimden 1. ASUS U57A-BBL4 Front Panel Assembly Replacement: adım 9, 3 resimden 2. ASUS U57A-BBL4 Front Panel Assembly Replacement: adım 9, 3 resimden 3.
    • Starting in a corner of the keyboard, pry the keyboard from the laptop using a plastic opening tool.
    • Remove the ribbon cable on the bottom of the keyboard by lifting up on the tape and pulling up.
    • The front panel is now loose from the laptop.
Sonuç
Isabella Bernardi
671 İtibar
6 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S2-G4, Julie Fall 2017 UMass Dartmouth, Team S2-G4, Julie Fall 2017 üyesi
UMASSD-JULIE-F17S2G4
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 8
Her zaman: 199
