Ana içeriğe geç
ASUS UX50V-RX05 Keyboard Replacement
Neye ihtiyacın var
  1. ASUS UX50V-RX05 Keyboard Replacement, Keyboard: adım 1, 3 resimden 1. ASUS UX50V-RX05 Keyboard Replacement, Keyboard: adım 1, 3 resimden 2. ASUS UX50V-RX05 Keyboard Replacement, Keyboard: adım 1, 3 resimden 3.
    • Make sure the device is powered off and the battery is removed before beginning.
    • Use the Plastic Opening tool to pry the five slots up at the top of the keyboard.
    FixBot'a Sor
    Yorum Ekle
  2. ASUS UX50V-RX05 Keyboard Replacement: adım 2, 2 resimden 1. ASUS UX50V-RX05 Keyboard Replacement: adım 2, 2 resimden 2.
    • Lift the keyboard enough to expose the two ribbon connectors (LCD flex cable and flex band).
    • Use the Plastic Opening tool to push open the two black clips on each side of the connecting cords.
    • Remove the cable after pushing out the two black clips.
    FixBot'a Sor
    Yorum Ekle
  3. ASUS UX50V-RX05 Keyboard Replacement: adım 3, 2 resimden 1. ASUS UX50V-RX05 Keyboard Replacement: adım 3, 2 resimden 2.
    • Push out each end of the black clip with a plastic opening tool or nylon spudger to remove the ribbon cable.
    • Remove the cable after pushing out both black clips.
    • Remove the keyboard.
    FixBot'a Sor
    Yorum Ekle
Sonuç
James
663 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 20-2, Remmell Spring 2017 USF Tampa, Team 20-2, Remmell Spring 2017 üyesi
USFT-REMMELL-S17S20G2
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 33
Her zaman: 665
