Ana içeriğe geç
ASUS UX50V-RX05 Motherboard Replacement
Neye ihtiyacın var
    1. ASUS UX50V-RX05 Motherboard Replacement, Keyboard: adım 1, 3 resimden 1. ASUS UX50V-RX05 Motherboard Replacement, Keyboard: adım 1, 3 resimden 2. ASUS UX50V-RX05 Motherboard Replacement, Keyboard: adım 1, 3 resimden 3.
      • Make sure the device is powered off and the battery is removed before beginning.
      • Use the Plastic Opening tool to pry the five slots up at the top of the keyboard.
      FixBot'a Sor
      Yorum Ekle
    2. ASUS UX50V-RX05 Motherboard Replacement: adım 2, 2 resimden 1. ASUS UX50V-RX05 Motherboard Replacement: adım 2, 2 resimden 2.
      • Lift the keyboard enough to expose the two ribbon connectors (LCD flex cable and flex band).
      • Use the Plastic Opening tool to push open the two black clips on each side of the connecting cords.
      • Remove the cable after pushing out the two black clips.
      FixBot'a Sor
      Yorum Ekle
    3. ASUS UX50V-RX05 Motherboard Replacement: adım 3, 2 resimden 1. ASUS UX50V-RX05 Motherboard Replacement: adım 3, 2 resimden 2.
      • Push out each end of the black clip with a plastic opening tool or nylon spudger to remove the ribbon cable.
      • Remove the cable after pushing out both black clips.
      • Remove the keyboard.
      FixBot'a Sor
      Yorum Ekle
    1. ASUS UX50V-RX05 Motherboard Replacement, Case Removal: adım 4, 3 resimden 1. ASUS UX50V-RX05 Motherboard Replacement, Case Removal: adım 4, 3 resimden 2. ASUS UX50V-RX05 Motherboard Replacement, Case Removal: adım 4, 3 resimden 3.
      • Remove the thirteen 5 mm J0 screws from the back of the laptop.
      • With the keyboard removed, use the spudger tool to pry around the edge of the laptop until it is free.
      FixBot'a Sor
      Yorum Ekle
    2. ASUS UX50V-RX05 Motherboard Replacement: adım 5, 2 resimden 1. ASUS UX50V-RX05 Motherboard Replacement: adım 5, 2 resimden 2.
      • Use the spudger tool to unplug the two cords from the body by pushing on the tabs on both sides of the plug.
      FixBot'a Sor
      Yorum Ekle
    3. ASUS UX50V-RX05 Motherboard Replacement: adım 6, 3 resimden 1. ASUS UX50V-RX05 Motherboard Replacement: adım 6, 3 resimden 2. ASUS UX50V-RX05 Motherboard Replacement: adım 6, 3 resimden 3.
      • With the previous two cords unplugged and out of the way, you can work on unplugging the black cord.
      • Use your fingers to pull up on the clear tab, or use the spudger tool to push out both sides of the connector.
      FixBot'a Sor
      Yorum Ekle
    4. ASUS UX50V-RX05 Motherboard Replacement: adım 7, 1 resimden 1.
      • Carefully lift and remove the plastic cover to avoid damaging anything.
      FixBot'a Sor
      Yorum Ekle
    1. ASUS UX50V-RX05 Motherboard Replacement, Optical Drive: adım 8, 2 resimden 1. ASUS UX50V-RX05 Motherboard Replacement, Optical Drive: adım 8, 2 resimden 2.
      • Remove the four 5 mm J0 screws surrounding the Optical Drive.
      • Remove the optical drive by pulling it out and away from the connector.
      FixBot'a Sor
      Yorum Ekle
    1. ASUS UX50V-RX05 Motherboard Replacement, Motherboard: adım 9, 3 resimden 1. ASUS UX50V-RX05 Motherboard Replacement, Motherboard: adım 9, 3 resimden 2. ASUS UX50V-RX05 Motherboard Replacement, Motherboard: adım 9, 3 resimden 3.
      • Use the Plastic Opening Tool to unplug the blue cord on the Motherboard.
      FixBot'a Sor
      Yorum Ekle
    2. ASUS UX50V-RX05 Motherboard Replacement: adım 10, 2 resimden 1. ASUS UX50V-RX05 Motherboard Replacement: adım 10, 2 resimden 2.
      • Remove the five 4 mm Phillips head 5 mm long screws that have white arrows pointing to them with the screwdriver.
      FixBot'a Sor
      Yorum Ekle
    3. ASUS UX50V-RX05 Motherboard Replacement: adım 11, 3 resimden 1. ASUS UX50V-RX05 Motherboard Replacement: adım 11, 3 resimden 2. ASUS UX50V-RX05 Motherboard Replacement: adım 11, 3 resimden 3.
      • Lift the Motherboard with your fingers by reaching underneath the Motherboard and prying.
      FixBot'a Sor
      Yorum Ekle
    4. ASUS UX50V-RX05 Motherboard Replacement: adım 12, 3 resimden 1. ASUS UX50V-RX05 Motherboard Replacement: adım 12, 3 resimden 2. ASUS UX50V-RX05 Motherboard Replacement: adım 12, 3 resimden 3.
      • Remove the two 4 mm Phillips head 5 mm long screws from the fan using the screwdriver.
      • Using the Spudger, carefully remove the white connector and lift the fan out of the casing.
      FixBot'a Sor
      Yorum Ekle
    5. ASUS UX50V-RX05 Motherboard Replacement: adım 13, 3 resimden 1. ASUS UX50V-RX05 Motherboard Replacement: adım 13, 3 resimden 2. ASUS UX50V-RX05 Motherboard Replacement: adım 13, 3 resimden 3.
      • Slowly lift the motherboard up towards you being careful as to not rip any cords out of the bottom.
      • Using the Spudger, remove the connector towards the bottom of the motherboard.
      • Remove the motherboard from the casing.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
James
663 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 20-2, Remmell Spring 2017 USF Tampa, Team 20-2, Remmell Spring 2017 üyesi
USFT-REMMELL-S17S20G2
4 Üyeler
54 adet Kılavuz yazıldı
1Rehber Yorum
From your knowledge is that mother board from the asus ux50v upgrade-able? is the processor integrated into the board?
A Snow - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 74
Her zaman: 975
