Ana içeriğe geç
ASUS UX50V-RX05 Optical Drive Replacement
Neye ihtiyacın var
  1. ASUS UX50V-RX05 Optical Drive Replacement, Keyboard: adım 1, 3 resimden 1. ASUS UX50V-RX05 Optical Drive Replacement, Keyboard: adım 1, 3 resimden 2. ASUS UX50V-RX05 Optical Drive Replacement, Keyboard: adım 1, 3 resimden 3.
    • Make sure the device is powered off and the battery is removed before beginning.
    • Use the Plastic Opening tool to pry the five slots up at the top of the keyboard.
    FixBot'a Sor
    Yorum Ekle
  2. ASUS UX50V-RX05 Optical Drive Replacement: adım 2, 2 resimden 1. ASUS UX50V-RX05 Optical Drive Replacement: adım 2, 2 resimden 2.
    • Lift the keyboard enough to expose the two ribbon connectors (LCD flex cable and flex band).
    • Use the Plastic Opening tool to push open the two black clips on each side of the connecting cords.
    • Remove the cable after pushing out the two black clips.
    FixBot'a Sor
    Yorum Ekle
  3. ASUS UX50V-RX05 Optical Drive Replacement: adım 3, 2 resimden 1. ASUS UX50V-RX05 Optical Drive Replacement: adım 3, 2 resimden 2.
    • Push out each end of the black clip with a plastic opening tool or nylon spudger to remove the ribbon cable.
    • Remove the cable after pushing out both black clips.
    • Remove the keyboard.
    FixBot'a Sor
    Yorum Ekle
  4. ASUS UX50V-RX05 Optical Drive Replacement, Case Removal: adım 4, 3 resimden 1. ASUS UX50V-RX05 Optical Drive Replacement, Case Removal: adım 4, 3 resimden 2. ASUS UX50V-RX05 Optical Drive Replacement, Case Removal: adım 4, 3 resimden 3.
    • Remove the thirteen 5 mm J0 screws from the back of the laptop.
    • With the keyboard removed, use the spudger tool to pry around the edge of the laptop until it is free.
    FixBot'a Sor
    Yorum Ekle
  5. ASUS UX50V-RX05 Optical Drive Replacement: adım 5, 2 resimden 1. ASUS UX50V-RX05 Optical Drive Replacement: adım 5, 2 resimden 2.
    • Use the spudger tool to unplug the two cords from the body by pushing on the tabs on both sides of the plug.
    FixBot'a Sor
    Yorum Ekle
  6. ASUS UX50V-RX05 Optical Drive Replacement: adım 6, 3 resimden 1. ASUS UX50V-RX05 Optical Drive Replacement: adım 6, 3 resimden 2. ASUS UX50V-RX05 Optical Drive Replacement: adım 6, 3 resimden 3.
    • With the previous two cords unplugged and out of the way, you can work on unplugging the black cord.
    • Use your fingers to pull up on the clear tab, or use the spudger tool to push out both sides of the connector.
    FixBot'a Sor
    Yorum Ekle
  7. ASUS UX50V-RX05 Optical Drive Replacement: adım 7, 1 resimden 1.
    • Carefully lift and remove the plastic cover to avoid damaging anything.
    FixBot'a Sor
    Yorum Ekle
  8. ASUS UX50V-RX05 Optical Drive Replacement, Optical Drive: adım 8, 2 resimden 1. ASUS UX50V-RX05 Optical Drive Replacement, Optical Drive: adım 8, 2 resimden 2.
    • Remove the four 5 mm J0 screws surrounding the Optical Drive.
    • Remove the optical drive by pulling it out and away from the connector.
    FixBot'a Sor
    Yorum Ekle
Sonuç
James
663 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 20-2, Remmell Spring 2017 USF Tampa, Team 20-2, Remmell Spring 2017 üyesi
USFT-REMMELL-S17S20G2
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 27
Her zaman: 448
