Ana içeriğe geç
ASUS VG248 Disassembly
Neye ihtiyacın var
  1. ASUS VG248 Disassembly, ASUS VG248 Disassembly: adım 1, 2 resimden 1. ASUS VG248 Disassembly, ASUS VG248 Disassembly: adım 1, 2 resimden 2.
    • Before you begin, lay the monitor face down on a smooth, clean surface.
    • Four rubbery covers hide four screws in the rear of the monitor.
    • Pry out the plastic covers with a stiff pointed tool, like a metal spudger.
    FixBot'a Sor
    Yorum Ekle
  2. ASUS VG248 Disassembly: adım 2, 1 resimden 1.
    • Remove the four 13.4 mm Philips #1 screws securing the monitor stand.
    FixBot'a Sor
    Yorum Ekle
  3. ASUS VG248 Disassembly: adım 3, 2 resimden 1. ASUS VG248 Disassembly: adım 3, 2 resimden 2.
    • Remove the stand from the display.
    FixBot'a Sor
    Yorum Ekle
  4. ASUS VG248 Disassembly: adım 4, 2 resimden 1. ASUS VG248 Disassembly: adım 4, 2 resimden 2.
    • The display bezel is held to the rear case by plastic clips that can be released by pulling straight up on the bezel.
    • Rather than use any prying tools that could damage the LCD, it's best to just pull with your fingers. A thin cloth will both protect your fingertips and prevent you from smudging the LCD.
    • Lay the cloth over one of the long edges of the display.
    • Grip the side of the bezel through the cloth and lift straight up. A few clips in the center will pop free.
    • Be careful to pull straight up, and not pry against the display. Pushing down on the display could damage it.
    FixBot'a Sor
    Yorum Ekle
  5. ASUS VG248 Disassembly: adım 5, 2 resimden 1. ASUS VG248 Disassembly: adım 5, 2 resimden 2.
    • Repeat the procedure around the display, lifting up the center of the next side.
    FixBot'a Sor
    Yorum Ekle
  6. ASUS VG248 Disassembly: adım 6, 2 resimden 1. ASUS VG248 Disassembly: adım 6, 2 resimden 2.
    • Move around to the other long side and lift up on the center of the bezel.
    FixBot'a Sor
    Yorum Ekle
  7. ASUS VG248 Disassembly: adım 7, 2 resimden 1. ASUS VG248 Disassembly: adım 7, 2 resimden 2.
    • Grip the center of the final side and lift the bezel away from the rear case.
    FixBot'a Sor
    Yorum Ekle
  8. ASUS VG248 Disassembly: adım 8, 2 resimden 1. ASUS VG248 Disassembly: adım 8, 2 resimden 2.
    • Now that you've freed the centers of the four sides, it's time to move on to the corners.
    • Each corner is secured by two large clips that can't be freed by just pulling straight up like you did with the sides.
    • In the next step, you'll be pushing in on the corner clip on the left of the bottom edge of the bezel.
    FixBot'a Sor
    Yorum Ekle
  9. ASUS VG248 Disassembly: adım 9, 2 resimden 1. ASUS VG248 Disassembly: adım 9, 2 resimden 2.
    Bu adımda kullanılan alet:
    Jimmy
    $7.95
    • Using a thin stiff prying device, like a Jimmy, press in against the bottom clip in the lower left corner (beneath the HDMI logo).
    • While pressing the clip in, pull up on the lower edge of the bezel. The entire corner should pop free.
    FixBot'a Sor
    Yorum Ekle
  10. ASUS VG248 Disassembly: adım 10, 3 resimden 1. ASUS VG248 Disassembly: adım 10, 3 resimden 2. ASUS VG248 Disassembly: adım 10, 3 resimden 3.
    • Once you've freed one corner, you should be able to gently twist the bezel off, freeing all of the remaining corners.
    • If any corners are particularly stubborn, repeat the previous step on the difficult corner.
    FixBot'a Sor
    Yorum Ekle
  11. ASUS VG248 Disassembly: adım 11, 1 resimden 1.
    • Remove the bezel.
    FixBot'a Sor
    Yorum Ekle
  12. ASUS VG248 Disassembly: adım 12, 2 resimden 1. ASUS VG248 Disassembly: adım 12, 2 resimden 2.
    • Lift the LCD out of the rear case.
    • The row of adjustment buttons will come out of the case with the display, attached by a thin ribbon cable. Take care not to damage the cable.
    FixBot'a Sor
    Yorum Ekle
  13. ASUS VG248 Disassembly: adım 13, 1 resimden 1.
    • With the casing removed, you now have access to the button board, cables, and the housing over the motherboard components.
    FixBot'a Sor
    Yorum Ekle
Sonuç
23 farklı kişi bu kılavuzu tamamladı.
Sam Goldheart
477.637 İtibar
538 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
122 Üyeler
27.484 adet Kılavuz yazıldı
11Kılavuz Yorumları
Do you know of any place that sell the replacement lcd screen?
treymcbrd - Yanıt Paylaş
Hi there, I have a little thunderbug trapped in the LCD is it possible to take the metal casing at the front of to reomve said bug? Thanks
TJ Grainger - Yanıt Paylaş
You could yes, but be very careful NOT to introduce dust into the panel!
Bertus van den Dikkenberg - Yanıt Paylaş
Hi. A really small bug got stuck within my screen and I accidentally squished it so now it’s dead in there and I want to clean it. How would I remove the top layer of the screen? Because from what I can see it seems like it got squished between the glass and the actual LCD screen itself.
Carl Viernes - Yanıt Paylaş
Me too, same issue, a very small bug I thaught was outside, acutally was inside and I squeezed it. It's very small but the dot is disturbing.
Is it possibile to take a part the layers of the LCD screen?
I have an ASUS PA248
Thank you
Piero - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 29
Son 7 gün: 162
Son 30 gün: 726
Her zaman: 137,054
