Ana içeriğe geç
ASUS VivoBook Flip TP501U Hard Drive Replacement
Neye ihtiyacın var
  1. ASUS VivoBook Flip TP501U Hard Drive Replacement, Keyboard Panel: adım 1, 2 resimden 1. ASUS VivoBook Flip TP501U Hard Drive Replacement, Keyboard Panel: adım 1, 2 resimden 2.
    • Open the laptop until it is flat and lay it screen down.
    • Remove eight 9.6mm Phillips #00 screws from the bottom of the laptop.
    • Remove two 4.8mm Phillips from the corners of the device.
  2. ASUS VivoBook Flip TP501U Hard Drive Replacement: adım 2, 1 resimden 1.
    • Turn the device face up.
    • Use the plastic Opening Pick to separate the keyboard panel from the chassis that was just unscrewed.
    • Pull the panel away from the chassis CAREFULLY, as there are ribbon cables attached between the keyboard and internal electronics.
  3. ASUS VivoBook Flip TP501U Hard Drive Replacement: adım 3, 1 resimden 1.
    • With the keyboard panel pulled up, detach the two ribbon cables from the motherboard using the blue tabs on the cables.
    • Remove the keyboard panel completely.
  4. ASUS VivoBook Flip TP501U Hard Drive Replacement, Hard Drive: adım 4, 2 resimden 1. ASUS VivoBook Flip TP501U Hard Drive Replacement, Hard Drive: adım 4, 2 resimden 2.
    • Unscrew the five 4.8mm Phillips #00 screws holding in the hard drive mounting bracket.
    • Slide the mounting bracket towards the battery to disconnect the hard drive from the motherboard.
  5. ASUS VivoBook Flip TP501U Hard Drive Replacement: adım 5, 1 resimden 1.
    • Unscrew the hard drive from the mounting bracket.
    • Remove the hard drive from the mounting bracket.
    • At the time of guide creation, the hard drive was not in the device.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 14
Her zaman: 1,542
