Ana içeriğe geç
ASUS VivoBook Flip TP501U WiFi Card Replacement
Neye ihtiyacın var
  1. ASUS VivoBook Flip TP501U WiFi Card Replacement, Keyboard Panel: adım 1, 2 resimden 1. ASUS VivoBook Flip TP501U WiFi Card Replacement, Keyboard Panel: adım 1, 2 resimden 2.
    • Open the laptop until it is flat and lay it screen down.
    • Remove eight 9.6mm Phillips #00 screws from the bottom of the laptop.
    • Remove two 4.8mm Phillips from the corners of the device.
  2. ASUS VivoBook Flip TP501U WiFi Card Replacement: adım 2, 1 resimden 1.
    • Turn the device face up.
    • Use the plastic Opening Pick to separate the keyboard panel from the chassis that was just unscrewed.
    • Pull the panel away from the chassis CAREFULLY, as there are ribbon cables attached between the keyboard and internal electronics.
  3. ASUS VivoBook Flip TP501U WiFi Card Replacement: adım 3, 1 resimden 1.
    • With the keyboard panel pulled up, detach the two ribbon cables from the motherboard using the blue tabs on the cables.
    • Remove the keyboard panel completely.
  4. ASUS VivoBook Flip TP501U WiFi Card Replacement, WiFi Card: adım 4, 3 resimden 1. ASUS VivoBook Flip TP501U WiFi Card Replacement, WiFi Card: adım 4, 3 resimden 2. ASUS VivoBook Flip TP501U WiFi Card Replacement, WiFi Card: adım 4, 3 resimden 3.
    • Locate and remove the single 3.17 mm screw holding in the WiFi card suing a Phillips #00 driver.
    • Disconnect the card from the motherboard by pulling down on the card.
    • Unplug the two black and white wires from the bottom of the card. They should pop off.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 5
Her zaman: 639
