Ana içeriğe geç
ASUS VivoBook S300C Hard Drive Replacement
Neye ihtiyacın var
  1. ASUS VivoBook S300C Hard Drive Replacement, Remove the bottom cover: adım 1, 1 resimden 1.
    • Remove the 10 screws on the back cover.
    • Some screws are missing from this system. You should take your own notes to make sure you put the correct screws in during reassembly.
  2. ASUS VivoBook S300C Hard Drive Replacement, Remove the hard drive cable: adım 2, 1 resimden 1.
    • Remove the hard drive from the laptop. To do this, the cable is taped to the hard drive caddy. Remove the tape from the cable and disconnect the hard drive from the motherboard.
    • I am also missing screws here. Take your own notes to avoid misplacing screws during reassembly. They should all be the same length.
  3. ASUS VivoBook S300C Hard Drive Replacement, Remove the hard drive from the caddy: adım 3, 2 resimden 1. ASUS VivoBook S300C Hard Drive Replacement, Remove the hard drive from the caddy: adım 3, 2 resimden 2.
    • Remove the 4 screws holding the hard drive in the caddy. There are two screws on each side.
    • Reassemble the laptop by following the steps in reverse order. This is my first guide, so let me know what I did wrong so I can fix it.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Cameron
10.353 İtibar
1 Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
322 Üyeler
2.541 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 19
Her zaman: 3,509
