Ana içeriğe geç
ASUS VivoBook S300CA-BBI5T01 Battery Replacement
Neye ihtiyacın var
  1. ASUS VivoBook S300CA-BBI5T01 Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Place the laptop upside down so that the bottom panel is facing upwards.
  2. ASUS VivoBook S300CA-BBI5T01 Battery Replacement: adım 2, 1 resimden 1.
    • Unscrew the following 10 screws
    • Eight 5 mm Phillips head screws
    • Two 10 mm Phillips head screws
  3. ASUS VivoBook S300CA-BBI5T01 Battery Replacement: adım 3, 1 resimden 1.
    • Carefully peel the panel off of the bottom of the laptop.
  4. ASUS VivoBook S300CA-BBI5T01 Battery Replacement: adım 4, 1 resimden 1.
    • Remove the 7 screws holding the battery in place.
    • Six 3 mm Phillips head screws
    • One 5 mm Phillips head screw
  5. ASUS VivoBook S300CA-BBI5T01 Battery Replacement: adım 5, 1 resimden 1.
    • Disconnect the one flat topped wire connector by carefully using a plastic opening tool to pry up both sides and then lifting the connector from its socket.
  6. ASUS VivoBook S300CA-BBI5T01 Battery Replacement: adım 6, 1 resimden 1.
    • Slide out the battery.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Keith Rachels
595 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 3-4, Bhusal Spring 2016 UMass Dartmouth, Team 3-4, Bhusal Spring 2016 üyesi
UMASSD-BHUSAL-S16S3G4
2 Üyeler
Bir Yorum
Make the Save ESD ?
Konrad Aubreville - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 3,682
