Ana içeriğe geç
Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
ASUS VivoBook S300CA-BBI5T01 Fan Replacement
Neye ihtiyacın var
  1. ASUS VivoBook S300CA-BBI5T01 Fan Replacement, Fan: adım 1, 1 resimden 1.
    • Place the laptop upside down so that the bottom panel is facing upwards.
  2. ASUS VivoBook S300CA-BBI5T01 Fan Replacement: adım 2, 1 resimden 1.
    • Unscrew the following 10 screws
    • Eight 5 mm Phillips head screws
    • Two 10 mm Phillips head screws
  3. ASUS VivoBook S300CA-BBI5T01 Fan Replacement: adım 3, 1 resimden 1.
    • Carefully peel the panel off of the bottom of the laptop.
  4. ASUS VivoBook S300CA-BBI5T01 Fan Replacement: adım 4, 1 resimden 1.
    • Remove the following 6 screws:
    • Two 5 mm screws holding the fan down.
    • Four 3 mm screws holding the heat sink down
    • Removing one of these screws voids the device's warranty.
  5. ASUS VivoBook S300CA-BBI5T01 Fan Replacement: adım 5, 1 resimden 1.
    • Carefully disconnect the only sliding connector by using a plastic opening tool to pry the connector out.
  6. ASUS VivoBook S300CA-BBI5T01 Fan Replacement: adım 6, 1 resimden 1.
    • Remove the fan and heat sink by lifting it upwards.
  7. ASUS VivoBook S300CA-BBI5T01 Fan Replacement: adım 7, 2 resimden 1. ASUS VivoBook S300CA-BBI5T01 Fan Replacement: adım 7, 2 resimden 2.
    • Remove the tape holding the fan and heat sink together.
    • Before reassembly it is essential to clean off the old thermal paste from the processor and the heatsink and to apply new. How to apply thermal paste explains how.
Sonuç
Keith Rachels
595 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 3-4, Bhusal Spring 2016 UMass Dartmouth, Team 3-4, Bhusal Spring 2016 üyesi
UMASSD-BHUSAL-S16S3G4
2 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 1,742
