Ana içeriğe geç
ASUS VivoBook S400C Hard Drive Replacement
Neye ihtiyacın var
  1. ASUS VivoBook S400C Hard Drive Replacement, Remove the Bottom Cover: adım 1, 1 resimden 1.
    • Flip the device over and remove the ten 5.7 mm screws with a Phillips #0 screwdriver.
  2. ASUS VivoBook S400C Hard Drive Replacement: adım 2, 2 resimden 1. ASUS VivoBook S400C Hard Drive Replacement: adım 2, 2 resimden 2.
    • Use a spudger or your fingers to go around and lift the edges and release the back panel.
  3. ASUS VivoBook S400C Hard Drive Replacement, Disconnect the Battery: adım 3, 1 resimden 1.
    • Using a spudger, lift up the plug connecting the battery to the motherboard.
  4. ASUS VivoBook S400C Hard Drive Replacement, Battery: adım 4, 1 resimden 1.
    • With a Phillips #0 screwdriver, remove the four 5.7 mm screws holding the battery to the laptop.
  5. ASUS VivoBook S400C Hard Drive Replacement: adım 5, 1 resimden 1.
    • Carefully lift the battery up and out of the device.
  6. ASUS VivoBook S400C Hard Drive Replacement, Hard Drive: adım 6, 1 resimden 1.
    • Remove the three Phillips #0 screws holding the the hard drive in place:
    • Two 3.8 mm screws.
    • One 5.7 mm screw.
  7. ASUS VivoBook S400C Hard Drive Replacement: adım 7, 1 resimden 1.
    • Pull left and lift out the hard drive.
Sonuç
Tiana Curry
85 İtibar
1 Kılavuz yazıldı
Ekip
UC Santa Barbara, Team S4-G4, Bator Fall 2019 UC Santa Barbara, Team S4-G4, Bator Fall 2019 üyesi
UCSB-BATOR-F19S4G4
3 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 21
Her zaman: 2,007
