Ana içeriğe geç
ASUS VivoBook S400C Wifi Card Replacement
Neye ihtiyacın var
  1. ASUS VivoBook S400C Wifi Card Replacement, Remove the Bottom Cover: adım 1, 1 resimden 1.
    • Flip the device over and remove the ten 5.7 mm screws with a Phillips #0 screwdriver.
  2. ASUS VivoBook S400C Wifi Card Replacement: adım 2, 2 resimden 1. ASUS VivoBook S400C Wifi Card Replacement: adım 2, 2 resimden 2.
    • Use a spudger or your fingers to go around and lift the edges and release the back panel.
  3. ASUS VivoBook S400C Wifi Card Replacement, Disconnect the Battery: adım 3, 1 resimden 1.
    • Using a spudger, lift up the plug connecting the battery to the motherboard.
  4. ASUS VivoBook S400C Wifi Card Replacement, Wifi Card: adım 4, 2 resimden 1. ASUS VivoBook S400C Wifi Card Replacement, Wifi Card: adım 4, 2 resimden 2.
    • Use a spudger to release the cables from the wifi card.
  5. ASUS VivoBook S400C Wifi Card Replacement: adım 5, 1 resimden 1.
    • Remove the singular 3.8 mm screw with a Phillips #0 screwdriver.
  6. ASUS VivoBook S400C Wifi Card Replacement: adım 6, 1 resimden 1.
    • Pull the wifi card up and out.
Sonuç
Ashley Panduro
572 İtibar
3 adet Kılavuz yazıldı
Ekip
UC Santa Barbara, Team S4-G4, Bator Fall 2019 UC Santa Barbara, Team S4-G4, Bator Fall 2019 üyesi
UCSB-BATOR-F19S4G4
3 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 19
Her zaman: 763
