Ana içeriğe geç
ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement
Neye ihtiyacın var
  1. ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement, Hard Drive: adım 1, 3 resimden 1. ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement, Hard Drive: adım 1, 3 resimden 2. ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement, Hard Drive: adım 1, 3 resimden 3.
    • Flip the laptop onto its backside.
    • Use a Phillips #00 screwdriver to remove the nine 1.2 mm Phillips #00 screws screws attached to the laptop backing.
  2. ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement: adım 2, 2 resimden 1. ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement: adım 2, 2 resimden 2.
    • Remove the laptop backing with a prying tool. Use the prying tool between the keyboard and bottom grooves.
    • Start prying from the center of the laptop and work your way around the edges of the laptop to remove the keyboard panel.
    • It is recommended to use a plastic prying tool versus a metal prying tool as it could scratch your laptop.
  3. ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement: adım 3, 2 resimden 1. ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement: adım 3, 2 resimden 2.
    • Separate the laptop keyboard from the laptop backing.
    • Carefully remove the keyboard connector from the motherboard.
  4. ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement: adım 4, 2 resimden 1. ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement: adım 4, 2 resimden 2.
    • Remove the two 3 mm screws attached to the laptop's hard drive metal cage using the Phillips #00 screwdriver.
    • Once the screws have been removed, gently disconnect the hard drive by pulling the hard drive away from the integrated SATA port.
  5. ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement: adım 5, 2 resimden 1. ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement: adım 5, 2 resimden 2.
    • Remove the four 3 mm screws attached to hard drive metal cage using the Phillips #00 screwdriver.
    • Remove the hard drive from the bracket.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
I replaced the original sata into a ssd but it doesnt boot to windows. It gets stuck in bios. The ssd has an os already. It appears in the storage section but not in the boot list. I have already tried to boot the ssd to my computer and it works.
Christusjohn Leoncio L Salvani - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 17
Son 30 gün: 47
Her zaman: 1,704
