Ana içeriğe geç
ASUS Vivobook Q301LA-BSI5T17 Fan/Heatsink Replacement
Neye ihtiyacın var
  1. ASUS Vivobook Q301LA-BSI5T17 Fan/Heatsink Replacement, Back Case Housing: adım 1, 1 resimden 1.
    • Remove all ten 6mm Phillips #1 screws from the bottom of the computer chassis.
  2. ASUS Vivobook Q301LA-BSI5T17 Fan/Heatsink Replacement: adım 2, 1 resimden 1.
    • Carefully pry open the back cover from the laptop and place it to the side.
  3. ASUS Vivobook Q301LA-BSI5T17 Fan/Heatsink Replacement, Fan: adım 3, 1 resimden 1.
    • Remove three 5mm Phillips #1 screws that are holding the fan in place.
  4. ASUS Vivobook Q301LA-BSI5T17 Fan/Heatsink Replacement: adım 4, 2 resimden 1. ASUS Vivobook Q301LA-BSI5T17 Fan/Heatsink Replacement: adım 4, 2 resimden 2.
    • Carefully unplug the fan cable from the motherboard using a spudger or plastic opening tool.
  5. ASUS Vivobook Q301LA-BSI5T17 Fan/Heatsink Replacement: adım 5, 2 resimden 1. ASUS Vivobook Q301LA-BSI5T17 Fan/Heatsink Replacement: adım 5, 2 resimden 2.
    • Carefully use your hands to remove the fan by pulling it from the heatsink housing.
    • Do not use excessive force; there is a potential to break the plastic.
Sonuç
Amrinder Singh
277 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team S1-G2, Hovde Spring 2019 IUPUI, Team S1-G2, Hovde Spring 2019 üyesi
IUPUI-HOVDE-S19S1G2
3 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 304
