Giriş
The fan is the most crucial part of the ASUS Vivobook Q301LA-BSI5T17. If the fan doesn’t work properly you will run a risk of overheating your laptop. Once a laptop overheats you can cause multiple internal problems.
These steps will help you replace your fan and prevent your laptop from overheating.
Neye ihtiyacın var
Remove all ten 6mm Phillips #1 screws from the bottom of the computer chassis.
Neredeyse bitti!
Sonuç
