Ana içeriğe geç
ASUS Vivobook Q301LA-BSI5T17 Memory Card Replacement
Neye ihtiyacın var
  1. ASUS Vivobook Q301LA-BSI5T17 Memory Card Replacement, Back Case Housing: adım 1, 1 resimden 1.
    • Remove all ten 6mm Phillips #1 screws from the bottom of the computer chassis.
  2. ASUS Vivobook Q301LA-BSI5T17 Memory Card Replacement: adım 2, 1 resimden 1.
    • Carefully pry open the back cover from the laptop and place it to the side.
  3. ASUS Vivobook Q301LA-BSI5T17 Memory Card Replacement, Memory Card: adım 3, 2 resimden 1. ASUS Vivobook Q301LA-BSI5T17 Memory Card Replacement, Memory Card: adım 3, 2 resimden 2.
    • Lift the perforated metal cover up from the motherboard to expose the memory cards.
  4. ASUS Vivobook Q301LA-BSI5T17 Memory Card Replacement: adım 4, 2 resimden 1. ASUS Vivobook Q301LA-BSI5T17 Memory Card Replacement: adım 4, 2 resimden 2.
    • Once the cover is removed the RAM will be accessible.
    • Use your fingertips to pry out the metal guards outlining both of the sides of the memory card.
    • The RAM stick should then pop up to rest at an angle to the motherboard.
  5. ASUS Vivobook Q301LA-BSI5T17 Memory Card Replacement: adım 5, 1 resimden 1.
    • Using your fingertips, slide the memory card out from the plastic housing and remove it from the board.
    • Be sure to remove the card at the same angle at which it rests to avoid damaging the card or the contacts of the slot.
Sonuç
Mark Fanelli
97 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S1-G2, Hovde Spring 2019 IUPUI, Team S1-G2, Hovde Spring 2019 üyesi
IUPUI-HOVDE-S19S1G2
3 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 440
