Ana içeriğe geç
ASUS Vivobook Q301LA-BSI5T17 WIFI CHIP Replacement
Neye ihtiyacın var
  1. ASUS Vivobook Q301LA-BSI5T17 WIFI CHIP Replacement, Back Case Housing: adım 1, 1 resimden 1.
    • Remove all ten 6mm Phillips #1 screws from the bottom of the computer chassis.
  2. ASUS Vivobook Q301LA-BSI5T17 WIFI CHIP Replacement: adım 2, 1 resimden 1.
    • Carefully pry open the back cover from the laptop and place it to the side.
  3. ASUS Vivobook Q301LA-BSI5T17 WIFI CHIP Replacement, WIFI CHIP: adım 3, 3 resimden 1. ASUS Vivobook Q301LA-BSI5T17 WIFI CHIP Replacement, WIFI CHIP: adım 3, 3 resimden 2. ASUS Vivobook Q301LA-BSI5T17 WIFI CHIP Replacement, WIFI CHIP: adım 3, 3 resimden 3.
    • Locate the wifi module on the back of your laptop.
    • Use an iFixit opening tool to pry the black (Main) and the white (Aux) coaxial cable connectors upward.
  4. ASUS Vivobook Q301LA-BSI5T17 WIFI CHIP Replacement: adım 4, 1 resimden 1.
    • Remove the 5mm screw from the module using the Phillips PH1 screwdriver.
  5. ASUS Vivobook Q301LA-BSI5T17 WIFI CHIP Replacement: adım 5, 1 resimden 1.
    • Gently pull the WiFi module out of its housing from the motherboard.
    • Careful not to break or bend the metal contacts.
Sonuç
Amrinder Singh
277 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team S1-G2, Hovde Spring 2019 IUPUI, Team S1-G2, Hovde Spring 2019 üyesi
IUPUI-HOVDE-S19S1G2
3 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 9
Her zaman: 702
