Ana içeriğe geç
ASUS Vivobook S500CA Battery Replacement
Neye ihtiyacın var
  1. ASUS Vivobook S500CA Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the device over to where the back plate is facing up.
  2. ASUS Vivobook S500CA Battery Replacement: adım 2, 1 resimden 1.
    • Use a Philips Head PH1 screwdriver to remove 10 screws (3 1cm screws and 7 .5cm screws) around the perimeter of the back plate.
    • Place screws where they cannot be lost as they will be used to replace the back plate.
  3. ASUS Vivobook S500CA Battery Replacement: adım 3, 1 resimden 1.
    • Remove the back plate by lifting it straight up.
  4. ASUS Vivobook S500CA Battery Replacement: adım 4, 1 resimden 1.
    • Remove 9 (.5 cm) phillips screws around the edge of the battery.
  5. ASUS Vivobook S500CA Battery Replacement: adım 5, 1 resimden 1.
    • Lift up the battery to reveal the battery terminal.
  6. ASUS Vivobook S500CA Battery Replacement: adım 6, 1 resimden 1.
    • Unclip the battery terminal by prying straight up on the sides of the connector to release the clip.
Sonuç
Deric Huffman
101 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 13
Her zaman: 6,040
