Giriş
The IO board in the ASUS X42J contains vital ports including power, ethernet, and one USB port. This is the very last thing that can come out of this device, so this will be the most time consuming guide for this device.
Neye ihtiyacın var
Use the Phillips #0 screwdriver to remove the two screws on the back of the laptop.
Remove all screws located on the bottom plate of the laptop, beginning with the three located underneath the disc drive.
Remove the tape from the screen connector.
Remove the screws from the connector.
