Neye ihtiyacın var
Using a Spudger, gently pry up the keyboard.
Use the Phillips #0 screwdriver to remove the two screws on the back of the laptop.
Remove all screws located on the bottom plate of the laptop, beginning with the three located underneath the disc drive.
Neredeyse bitti!
Sonuç
Bir Yorum
First step is wrong; attempting to prise out the keyboard will damage it. First step should be to remove the screws which hold in the keyboard.
