Ana içeriğe geç
ASUS X44H-BBR4 Front Panel Replacement
Neye ihtiyacın var
  1. ASUS X44H-BBR4 Front Panel Replacement, Battery: adım 1, 2 resimden 1. ASUS X44H-BBR4 Front Panel Replacement, Battery: adım 1, 2 resimden 2.
    • Flip the device over.
  2. ASUS X44H-BBR4 Front Panel Replacement: adım 2, 3 resimden 1. ASUS X44H-BBR4 Front Panel Replacement: adım 2, 3 resimden 2. ASUS X44H-BBR4 Front Panel Replacement: adım 2, 3 resimden 3.
    • Slide the right lock button to the unlock position.
    • After it is unlocked, a red line will be visible.
  3. ASUS X44H-BBR4 Front Panel Replacement: adım 3, 2 resimden 1. ASUS X44H-BBR4 Front Panel Replacement: adım 3, 2 resimden 2.
    • Slide the left lock button into the unlock position and hold.
  4. ASUS X44H-BBR4 Front Panel Replacement: adım 4, 3 resimden 1. ASUS X44H-BBR4 Front Panel Replacement: adım 4, 3 resimden 2. ASUS X44H-BBR4 Front Panel Replacement: adım 4, 3 resimden 3.
    • While holding the left lock button in the unlock position, push the battery from the center away from you.
  5. ASUS X44H-BBR4 Front Panel Replacement, Keyboard: adım 5, 2 resimden 1. ASUS X44H-BBR4 Front Panel Replacement, Keyboard: adım 5, 2 resimden 2.
    • Open the laptop to show the keyboard.
  6. ASUS X44H-BBR4 Front Panel Replacement: adım 6, 1 resimden 1.
    • Look at the top row of the keyboard, you will see a space that has four latches holding the keyboard down.
    • The latches are located above the Esc key, the F5 key, between the F10 and F11 key and the Delete key.
  7. ASUS X44H-BBR4 Front Panel Replacement: adım 7, 3 resimden 1. ASUS X44H-BBR4 Front Panel Replacement: adım 7, 3 resimden 2. ASUS X44H-BBR4 Front Panel Replacement: adım 7, 3 resimden 3.
    • Don't pull too hard on the keys otherwise they may fall off.
    • Push the latch away from the keyboard using the spudger point.
    • While pushing the latches use a plastic opening tool and pull up on a key near it.
    • Continue along the rest of the keyboard until it is released at all four latches.
  8. ASUS X44H-BBR4 Front Panel Replacement: adım 8, 2 resimden 1. ASUS X44H-BBR4 Front Panel Replacement: adım 8, 2 resimden 2.
    • Push the keyboard away from the mouse track pad to unlock the bottom from the base.
    • Do not pull too hard because there is a ribbon connecting to keyboard to the motherboard.
  9. ASUS X44H-BBR4 Front Panel Replacement: adım 9, 2 resimden 1. ASUS X44H-BBR4 Front Panel Replacement: adım 9, 2 resimden 2.
    • Flip the keyboard over to reveal the back of it and what is underneath.
  10. ASUS X44H-BBR4 Front Panel Replacement: adım 10, 3 resimden 1. ASUS X44H-BBR4 Front Panel Replacement: adım 10, 3 resimden 2. ASUS X44H-BBR4 Front Panel Replacement: adım 10, 3 resimden 3.
    • Pull each end of the black ribbon cable piece towards the mouse track pad to unlock the ribbon connector piece.
    • Gently pull out the ribbon cable from the connector piece.
  11. ASUS X44H-BBR4 Front Panel Replacement: adım 11, 1 resimden 1.
    • Remove the keyboard completely.
  12. ASUS X44H-BBR4 Front Panel Replacement, Hard Drive: adım 12, 2 resimden 1. ASUS X44H-BBR4 Front Panel Replacement, Hard Drive: adım 12, 2 resimden 2.
    • Remove the two 9 mm Phillips head screws with the PH0 bit indicated by the red circles in the picture.
  13. ASUS X44H-BBR4 Front Panel Replacement: adım 13, 2 resimden 1. ASUS X44H-BBR4 Front Panel Replacement: adım 13, 2 resimden 2.
    • Once the screws are removed, slide the back panel away from the computer.
  14. ASUS X44H-BBR4 Front Panel Replacement: adım 14, 1 resimden 1.
    • Remove the 9mm Phillips head screw in the left bottom corner of the hard drive with the PH0 bit.
  15. ASUS X44H-BBR4 Front Panel Replacement: adım 15, 2 resimden 1. ASUS X44H-BBR4 Front Panel Replacement: adım 15, 2 resimden 2.
    • Slide the hard drive to the left, unlocking it from its default position.
  16. ASUS X44H-BBR4 Front Panel Replacement: adım 16, 2 resimden 1. ASUS X44H-BBR4 Front Panel Replacement: adım 16, 2 resimden 2.
    • Pull the hard drive upwards and take it out of its position.
  17. ASUS X44H-BBR4 Front Panel Replacement: adım 17, 3 resimden 1. ASUS X44H-BBR4 Front Panel Replacement: adım 17, 3 resimden 2. ASUS X44H-BBR4 Front Panel Replacement: adım 17, 3 resimden 3.
    • Remove two 3mm Phillips head screws, one located on each side of the metal casing holding the hard drive using the PH0 bit.
  18. ASUS X44H-BBR4 Front Panel Replacement: adım 18, 1 resimden 1.
    • Pull upwards on the metal casing and it will come off.
  19. ASUS X44H-BBR4 Front Panel Replacement, Front Panel: adım 19, 3 resimden 1. ASUS X44H-BBR4 Front Panel Replacement, Front Panel: adım 19, 3 resimden 2. ASUS X44H-BBR4 Front Panel Replacement, Front Panel: adım 19, 3 resimden 3.
    • Lift up the black lock holding the ribbon.
    • Using the blue tab, pull out the ribbon.
    • Pull gently on the ribbon to remove the risk of damaging the ribbon.
  20. ASUS X44H-BBR4 Front Panel Replacement: adım 20, 1 resimden 1.
  21. ASUS X44H-BBR4 Front Panel Replacement: adım 21, 2 resimden 1. ASUS X44H-BBR4 Front Panel Replacement: adım 21, 2 resimden 2.
    • Remove the five 9 mm Phillips head screws with the PH0 bit.
  22. ASUS X44H-BBR4 Front Panel Replacement: adım 22, 2 resimden 1. ASUS X44H-BBR4 Front Panel Replacement: adım 22, 2 resimden 2.
    • Flip the laptop on its side so that the red line indicated in the pictures is facing upwards.
  23. ASUS X44H-BBR4 Front Panel Replacement: adım 23, 2 resimden 1. ASUS X44H-BBR4 Front Panel Replacement: adım 23, 2 resimden 2.
    • Pull up on the disk drive and remove.
  24. ASUS X44H-BBR4 Front Panel Replacement: adım 24, 2 resimden 1. ASUS X44H-BBR4 Front Panel Replacement: adım 24, 2 resimden 2.
    • Close the laptop and flip it over.
    • Remove the six 12.5 mm screws Phillips head and the five 9 mm screws remaining with the PH0 bit.
  25. ASUS X44H-BBR4 Front Panel Replacement: adım 25, 3 resimden 1. ASUS X44H-BBR4 Front Panel Replacement: adım 25, 3 resimden 2. ASUS X44H-BBR4 Front Panel Replacement: adım 25, 3 resimden 3.
    • Flip the device back over and open the laptop.
    • Using the nylon or metal spudger, gently pry off the panel by moving the spudger along the seam.
    • You should hear clicking sounds as the front panel is being removed from the base.
  26. ASUS X44H-BBR4 Front Panel Replacement: adım 26, 1 resimden 1.
    • Remove the panel.
    • The laptop will now become heavier to the front so it will tend to fall on the back side of the screen.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Devaj Ramsamooj
824 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-3, Catania Fall 2015 UMass Dartmouth, Team 4-3, Catania Fall 2015 üyesi
UMASSD-CATANIA-F15S4G3
4 Üyeler
8 adet Kılavuz yazıldı
Bir Yorum
Great job! Always stayed away from tablets because of all the hassle. Your guide made it a breeze. Thank You, Thank You
anthois - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 9
Her zaman: 519
