Ana içeriğe geç
ASUS X44H-BBR4 Hard Drive Replacement
Neye ihtiyacın var
  1. ASUS X44H-BBR4 Hard Drive Replacement, Battery: adım 1, 2 resimden 1. ASUS X44H-BBR4 Hard Drive Replacement, Battery: adım 1, 2 resimden 2.
    • Flip the device over.
  2. ASUS X44H-BBR4 Hard Drive Replacement: adım 2, 3 resimden 1. ASUS X44H-BBR4 Hard Drive Replacement: adım 2, 3 resimden 2. ASUS X44H-BBR4 Hard Drive Replacement: adım 2, 3 resimden 3.
    • Slide the right lock button to the unlock position.
    • After it is unlocked, a red line will be visible.
  3. ASUS X44H-BBR4 Hard Drive Replacement: adım 3, 2 resimden 1. ASUS X44H-BBR4 Hard Drive Replacement: adım 3, 2 resimden 2.
    • Slide the left lock button into the unlock position and hold.
  4. ASUS X44H-BBR4 Hard Drive Replacement: adım 4, 3 resimden 1. ASUS X44H-BBR4 Hard Drive Replacement: adım 4, 3 resimden 2. ASUS X44H-BBR4 Hard Drive Replacement: adım 4, 3 resimden 3.
    • While holding the left lock button in the unlock position, push the battery from the center away from you.
  5. ASUS X44H-BBR4 Hard Drive Replacement, Hard Drive: adım 5, 2 resimden 1. ASUS X44H-BBR4 Hard Drive Replacement, Hard Drive: adım 5, 2 resimden 2.
    • Remove the two 9 mm Phillips head screws with the PH0 bit indicated by the red circles in the picture.
  6. ASUS X44H-BBR4 Hard Drive Replacement: adım 6, 2 resimden 1. ASUS X44H-BBR4 Hard Drive Replacement: adım 6, 2 resimden 2.
    • Once the screws are removed, slide the back panel away from the computer.
  7. ASUS X44H-BBR4 Hard Drive Replacement: adım 7, 1 resimden 1.
    • Remove the 9mm Phillips head screw in the left bottom corner of the hard drive with the PH0 bit.
  8. ASUS X44H-BBR4 Hard Drive Replacement: adım 8, 2 resimden 1. ASUS X44H-BBR4 Hard Drive Replacement: adım 8, 2 resimden 2.
    • Slide the hard drive to the left, unlocking it from its default position.
  9. ASUS X44H-BBR4 Hard Drive Replacement: adım 9, 2 resimden 1. ASUS X44H-BBR4 Hard Drive Replacement: adım 9, 2 resimden 2.
    • Pull the hard drive upwards and take it out of its position.
  10. ASUS X44H-BBR4 Hard Drive Replacement: adım 10, 3 resimden 1. ASUS X44H-BBR4 Hard Drive Replacement: adım 10, 3 resimden 2. ASUS X44H-BBR4 Hard Drive Replacement: adım 10, 3 resimden 3.
    • Remove two 3mm Phillips head screws, one located on each side of the metal casing holding the hard drive using the PH0 bit.
  11. ASUS X44H-BBR4 Hard Drive Replacement: adım 11, 1 resimden 1.
    • Pull upwards on the metal casing and it will come off.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Devaj Ramsamooj
824 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-3, Catania Fall 2015 UMass Dartmouth, Team 4-3, Catania Fall 2015 üyesi
UMASSD-CATANIA-F15S4G3
4 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 5
Her zaman: 1,235
