Ana içeriğe geç
ASUS X44H-BBR4 Keyboard Replacement
Neye ihtiyacın var
  1. ASUS X44H-BBR4 Keyboard Replacement, Keyboard: adım 1, 2 resimden 1. ASUS X44H-BBR4 Keyboard Replacement, Keyboard: adım 1, 2 resimden 2.
    • Open the laptop to show the keyboard.
  2. ASUS X44H-BBR4 Keyboard Replacement: adım 2, 1 resimden 1.
    • Look at the top row of the keyboard, you will see a space that has four latches holding the keyboard down.
    • The latches are located above the Esc key, the F5 key, between the F10 and F11 key and the Delete key.
  3. ASUS X44H-BBR4 Keyboard Replacement: adım 3, 3 resimden 1. ASUS X44H-BBR4 Keyboard Replacement: adım 3, 3 resimden 2. ASUS X44H-BBR4 Keyboard Replacement: adım 3, 3 resimden 3.
    • Don't pull too hard on the keys otherwise they may fall off.
    • Push the latch away from the keyboard using the spudger point.
    • While pushing the latches use a plastic opening tool and pull up on a key near it.
    • Continue along the rest of the keyboard until it is released at all four latches.
  4. ASUS X44H-BBR4 Keyboard Replacement: adım 4, 2 resimden 1. ASUS X44H-BBR4 Keyboard Replacement: adım 4, 2 resimden 2.
    • Push the keyboard away from the mouse track pad to unlock the bottom from the base.
    • Do not pull too hard because there is a ribbon connecting to keyboard to the motherboard.
  5. ASUS X44H-BBR4 Keyboard Replacement: adım 5, 2 resimden 1. ASUS X44H-BBR4 Keyboard Replacement: adım 5, 2 resimden 2.
    • Flip the keyboard over to reveal the back of it and what is underneath.
  6. ASUS X44H-BBR4 Keyboard Replacement: adım 6, 3 resimden 1. ASUS X44H-BBR4 Keyboard Replacement: adım 6, 3 resimden 2. ASUS X44H-BBR4 Keyboard Replacement: adım 6, 3 resimden 3.
    • Pull each end of the black ribbon cable piece towards the mouse track pad to unlock the ribbon connector piece.
    • Gently pull out the ribbon cable from the connector piece.
  7. ASUS X44H-BBR4 Keyboard Replacement: adım 7, 1 resimden 1.
    • Remove the keyboard completely.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Kelly Merlo
500 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-3, Catania Fall 2015 UMass Dartmouth, Team 4-3, Catania Fall 2015 üyesi
UMASSD-CATANIA-F15S4G3
4 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 1,177
