Ana içeriğe geç
ASUS X502CA Battery Replacement
Neye ihtiyacın var
    1. ASUS X502CA Battery Replacement, Palm Rest with Keyboard and Touch Pad: adım 1, 1 resimden 1.
      • Use the Phillips #00 screwdriver to remove the seven 90mm screws.
      • Use the Phillips #00 screwdriver to remove the four 50mm screws.
      FixBot'a Sor
      Yorum Ekle
    2. ASUS X502CA Battery Replacement: adım 2, 1 resimden 1.
      • Next, use the plastic opening tool to carefully pop off the keyboard cover panel.
      • Be cautious when pulling off the cover because there are cables you will have to disconnect before completely removing the panel.
      FixBot'a Sor
      Yorum Ekle
    3. ASUS X502CA Battery Replacement: adım 3, 2 resimden 1. ASUS X502CA Battery Replacement: adım 3, 2 resimden 2.
      Bu adımda kullanılan alet:
      • Lift palm rest and unplug keyboard cable and touchpad cable using tweezers. After these two cables have been unplugged you can remove the keyboard cover panel.
      FixBot'a Sor
      Yorum Ekle
    4. ASUS X502CA Battery Replacement: adım 4, 2 resimden 1. ASUS X502CA Battery Replacement: adım 4, 2 resimden 2.
      • Lift Palm Rest away.
      • Replace with new palm rest.
      FixBot'a Sor
      Yorum Ekle
    1. ASUS X502CA Battery Replacement, Battery: adım 5, 1 resimden 1.
      • Next, locate the battery in the front of laptop (closest to you).
      FixBot'a Sor
      Yorum Ekle
    2. ASUS X502CA Battery Replacement: adım 6, 1 resimden 1.
      • Unplug the battery from the laptop in the upper right hand corner of the battery using tweezers.
      • If battery is not unplugged, motherboard may shock you.
      FixBot'a Sor
      Yorum Ekle
    3. ASUS X502CA Battery Replacement: adım 7, 2 resimden 1. ASUS X502CA Battery Replacement: adım 7, 2 resimden 2.
      • Use the Phillips #00 Screwdriver to carefully remove the 6 screws holding the battery in place.
      • Once you have removed all six screws carefully lift the battery out and dispose.
      • Each screw is 50 mm in length and 15 mm in diameter.
      FixBot'a Sor
      Yorum Ekle
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
David Conner
292 İtibar
2 adet Kılavuz yazıldı
Ekip
Clemson, Team 14-1, Shirley Winter 2015 Clemson, Team 14-1, Shirley Winter 2015 üyesi
CLEM-SHIRLEY-W15S14G1
5 Üyeler
35 adet Kılavuz yazıldı
1Rehber Yorum
Thank you for posting this
SteveFFFFF 0 - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 38
Her zaman: 15,258
