Ana içeriğe geç
ASUS X502CA Fan Replacement
Neye ihtiyacın var
  1. ASUS X502CA Fan Replacement, Fan: adım 1, 1 resimden 1.
    • Use a Phillips #00 screwdriver to remove:
    • Eight 9 mm screws.
    • Four 5 mm screws.
  2. ASUS X502CA Fan Replacement: adım 2, 1 resimden 1.
    • Remove the keyboard cover panel by using a plastic opening tool to carefully pop off the clips around the perimeter.
    • Be cautious when pulling off the cover because there are cables you will have to disconnect before completely removing the panel.
  3. ASUS X502CA Fan Replacement: adım 3, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • The keyboard cover panel is connected to the motherboard with ribbons; be careful not to damage them.
    • Lift the keyboard cover carefully.
    • Disconnect the keyboard and touch-pad ribbons using tweezers.
  4. ASUS X502CA Fan Replacement: adım 4, 1 resimden 1.
    • Remove the keyboard cover panel.
  5. ASUS X502CA Fan Replacement: adım 5, 1 resimden 1.
    • Fold up the black plastic arms securing the cables and disconnect them using tweezers or finger nails.
    • If these are not unplugged, the motherboard may shock you.
  6. ASUS X502CA Fan Replacement: adım 6, 1 resimden 1.
    • Disconnect the remaining connectors using tweezers or your finger nails.
  7. ASUS X502CA Fan Replacement: adım 7, 1 resimden 1.
    • Remove the six 5 mm screws using the Phillips #00 screwdriver.
  8. ASUS X502CA Fan Replacement: adım 8, 1 resimden 1.
    • Flip the motherboard over and away from the screen.
  9. ASUS X502CA Fan Replacement: adım 9, 1 resimden 1.
    • Remove the two 5 mm screws with a Phillips #00 screwdriver.
  10. ASUS X502CA Fan Replacement: adım 10, 1 resimden 1.
    • Unplug the fan's power connector using tweezers or your fingernails.
  11. ASUS X502CA Fan Replacement: adım 11, 1 resimden 1.
    • Peel off the marked strip using your fingers.
  12. ASUS X502CA Fan Replacement: adım 12, 1 resimden 1.
    • Lift the fan up and away from the motherboard.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
David Conner
292 İtibar
2 adet Kılavuz yazıldı
Ekip
Clemson, Team 14-1, Shirley Winter 2015 Clemson, Team 14-1, Shirley Winter 2015 üyesi
CLEM-SHIRLEY-W15S14G1
5 Üyeler
5 adet Kılavuz yazıldı
2 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 8
Her zaman: 7,867
