Ana içeriğe geç
ASUS X502CA Palm Rest with Keyboard and Touch Pad Replacement
Neye ihtiyacın var
  1. ASUS X502CA Palm Rest with Keyboard and Touch Pad Replacement, Palm Rest with Keyboard and Touch Pad: adım 1, 1 resimden 1.
    • Use the Phillips #00 screwdriver to remove the seven 90mm screws.
    • Use the Phillips #00 screwdriver to remove the four 50mm screws.
  2. ASUS X502CA Palm Rest with Keyboard and Touch Pad Replacement: adım 2, 1 resimden 1.
    • Next, use the plastic opening tool to carefully pop off the keyboard cover panel.
    • Be cautious when pulling off the cover because there are cables you will have to disconnect before completely removing the panel.
  3. ASUS X502CA Palm Rest with Keyboard and Touch Pad Replacement: adım 3, 2 resimden 1. ASUS X502CA Palm Rest with Keyboard and Touch Pad Replacement: adım 3, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Lift palm rest and unplug keyboard cable and touchpad cable using tweezers. After these two cables have been unplugged you can remove the keyboard cover panel.
  4. ASUS X502CA Palm Rest with Keyboard and Touch Pad Replacement: adım 4, 2 resimden 1. ASUS X502CA Palm Rest with Keyboard and Touch Pad Replacement: adım 4, 2 resimden 2.
    • Lift Palm Rest away.
    • Replace with new palm rest.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Michael Morrow
258 İtibar
1 Kılavuz yazıldı
Ekip
Clemson, Team 14-1, Shirley Winter 2015 Clemson, Team 14-1, Shirley Winter 2015 üyesi
CLEM-SHIRLEY-W15S14G1
5 Üyeler
5 adet Kılavuz yazıldı
Bir Yorum
there is no reason to disassemble the top-half of the laptop.
seanwilson684 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 1,922
