Ana içeriğe geç
ASUS X550LB-DS71 Display Panel Replacement
Neye ihtiyacın var
    1. ASUS X550LB-DS71 Display Panel Replacement, Display Panel: adım 1, 3 resimden 1. ASUS X550LB-DS71 Display Panel Replacement, Display Panel: adım 1, 3 resimden 2. ASUS X550LB-DS71 Display Panel Replacement, Display Panel: adım 1, 3 resimden 3.
      • Flip open the laptop with the screen facing towards you.
      • Using the plastic opening tool, remove the square tape from the marked locations.
      • Use the Phillips #0 Screwdriver to remove the two 2mm screws from those locations.
      FixBot'a Sor
      Yorum Ekle
    2. ASUS X550LB-DS71 Display Panel Replacement: adım 2, 2 resimden 1. ASUS X550LB-DS71 Display Panel Replacement: adım 2, 2 resimden 2.
      • Using the plastic opening tool, open the front cover of the laptop.
      • It is recommended that you start from a corner and run the tool along the edge of the cover.
      • Be careful not to bend or crack the cover.
      FixBot'a Sor
      Yorum Ekle
    3. ASUS X550LB-DS71 Display Panel Replacement: adım 3, 3 resimden 1. ASUS X550LB-DS71 Display Panel Replacement: adım 3, 3 resimden 2. ASUS X550LB-DS71 Display Panel Replacement: adım 3, 3 resimden 3.
      • Peel off the tape located on the left and right side of the display monitor.
      • Use the Phillips #0 screwdriver to remove the screws at the marked locations in each corner of the display.
      FixBot'a Sor
      Yorum Ekle
    4. ASUS X550LB-DS71 Display Panel Replacement: adım 4, 3 resimden 1. ASUS X550LB-DS71 Display Panel Replacement: adım 4, 3 resimden 2. ASUS X550LB-DS71 Display Panel Replacement: adım 4, 3 resimden 3.
      • Place the display monitor face down to expose the ribbon connector.
      • Remove the ribbon connector to separate the display monitor from the rest of the device.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Nathan Dyer
550 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S16-G1, Eyestone Fall 2017 USF Tampa, Team S16-G1, Eyestone Fall 2017 üyesi
USFT-EYESTONE-F17S16G1
4 Üyeler
34 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 14
Son 30 gün: 52
Her zaman: 1,450
