Giriş
The fan helps get rid of the excess heat in the laptop. A damaged fan can cause overheating and poor performance. This guide explains how to replace it.
Neye ihtiyacın var
Place the laptop on a flat surface with the bottom side facing upwards.
Using the Phillips #1 Screwdriver, remove the four 4mm screws in the back panel.
Using both hands, slide the back panel away from the laptop horizontally.
Bir başkası bu kılavuzu tamamladı.
1Rehber Yorum
my mouse of laptop not working pls guide to repaire
