Ana içeriğe geç
ASUS X550LB-DS71 Motherboard Replacement
Neye ihtiyacın var
  1. ASUS X550LB-DS71 Motherboard Replacement, Motherboard: adım 1, 3 resimden 1. ASUS X550LB-DS71 Motherboard Replacement, Motherboard: adım 1, 3 resimden 2. ASUS X550LB-DS71 Motherboard Replacement, Motherboard: adım 1, 3 resimden 3.
    • Make sure to switch off your laptop before starting.
    • Place the laptop on a flat surface with the bottom side facing upwards.
    • Using the Phillips #1 Screwdriver, remove the four 4mm screws in the back panel.
    • Using both hands, slide the back panel away from the laptop horizontally.
    FixBot'a Sor
    Yorum Ekle
  2. ASUS X550LB-DS71 Motherboard Replacement: adım 2, 1 resimden 1.
    • Using the Phillips #0 Screwdriver, remove the ten 2mm screws at the marked locations.
    • At this point, it is advised to disconnect the hard drive from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  3. ASUS X550LB-DS71 Motherboard Replacement: adım 3, 3 resimden 1. ASUS X550LB-DS71 Motherboard Replacement: adım 3, 3 resimden 2. ASUS X550LB-DS71 Motherboard Replacement: adım 3, 3 resimden 3.
    • Using the plastic opening tool, open the back cover of the laptop.
    • It is recommended that you start from a corner and run the tool along the edge of the cover.
    • Be careful not to bend or crack the cover.
    FixBot'a Sor
    Yorum Ekle
  4. ASUS X550LB-DS71 Motherboard Replacement: adım 4, 2 resimden 1. ASUS X550LB-DS71 Motherboard Replacement: adım 4, 2 resimden 2.
    • Locate the three ribbon connectors.
    • Using the plastic opening tool, flip up all three gray tabs and remove the ribbon connectors from the motherboard.
    • Once the tabs are released, the ribbons will be easy to remove. Do not pull on the ribbons.
    FixBot'a Sor
    Yorum Ekle
  5. ASUS X550LB-DS71 Motherboard Replacement: adım 5, 2 resimden 1. ASUS X550LB-DS71 Motherboard Replacement: adım 5, 2 resimden 2.
    • Locate the gold ribbon connecting the motherboard to the display.
    • Lift up the tape and disconnect the ribbon.
    FixBot'a Sor
    Yorum Ekle
  6. ASUS X550LB-DS71 Motherboard Replacement: adım 6, 2 resimden 1. ASUS X550LB-DS71 Motherboard Replacement: adım 6, 2 resimden 2.
    • Using the Phillips #0 Screwdriver, remove the nine 2mm screws at the marked locations.
    FixBot'a Sor
    Yorum Ekle
  7. ASUS X550LB-DS71 Motherboard Replacement: adım 7, 2 resimden 1. ASUS X550LB-DS71 Motherboard Replacement: adım 7, 2 resimden 2.
    • Disconnect the WLAN Card from the motherboard by pulling the connector upwards.
    • Disconnect the optical drive from the motherboard by sliding it to the right.
    FixBot'a Sor
    Yorum Ekle
  8. ASUS X550LB-DS71 Motherboard Replacement: adım 8, 3 resimden 1. ASUS X550LB-DS71 Motherboard Replacement: adım 8, 3 resimden 2. ASUS X550LB-DS71 Motherboard Replacement: adım 8, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Flip the motherboard to show the underside.
    • Locate the two square connections attached to the motherboard.
    • Disconnect them using blunt tweezers.
    FixBot'a Sor
    Yorum Ekle
  9. ASUS X550LB-DS71 Motherboard Replacement: adım 9, 3 resimden 1. ASUS X550LB-DS71 Motherboard Replacement: adım 9, 3 resimden 2. ASUS X550LB-DS71 Motherboard Replacement: adım 9, 3 resimden 3.
    • Using the Phillips #0 Screwdriver, remove the seven 2mm screws at the marked locations.
    • Remove the heat sink from the motherboard.
    FixBot'a Sor
    Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Nathan Dyer
550 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S16-G1, Eyestone Fall 2017 USF Tampa, Team S16-G1, Eyestone Fall 2017 üyesi
USFT-EYESTONE-F17S16G1
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 47
Her zaman: 2,670
