Ana içeriğe geç
ASUS X552LAV-BBI5N08 Fan Replacement
Neye ihtiyacın var
    1. ASUS X552LAV-BBI5N08 Fan Replacement, Battery: adım 1, 1 resimden 1.
      • Battery is not showed in pictures.
      • Flip the laptop face down.
      FixBot'a Sor
      Yorum Ekle
    2. ASUS X552LAV-BBI5N08 Fan Replacement: adım 2, 3 resimden 1. ASUS X552LAV-BBI5N08 Fan Replacement: adım 2, 3 resimden 2. ASUS X552LAV-BBI5N08 Fan Replacement: adım 2, 3 resimden 3.
      • Slide the right button to the left.
      • Hold the left button to the right.
      • While you hold the left button in position, slide the battery out by pushing it away from you.
      FixBot'a Sor
      Yorum Ekle
    1. ASUS X552LAV-BBI5N08 Fan Replacement, Fan: adım 3, 1 resimden 1.
      • Locate the bottom panel. It is at the opposite end of the battery.
      • Remove the two 12mm screws at the bottom panel with a Tri-wing Y1 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. ASUS X552LAV-BBI5N08 Fan Replacement: adım 4, 3 resimden 1. ASUS X552LAV-BBI5N08 Fan Replacement: adım 4, 3 resimden 2. ASUS X552LAV-BBI5N08 Fan Replacement: adım 4, 3 resimden 3.
      • Remove bottom panel by lifting it up.
      FixBot'a Sor
      Yorum Ekle
    3. ASUS X552LAV-BBI5N08 Fan Replacement: adım 5, 3 resimden 1. ASUS X552LAV-BBI5N08 Fan Replacement: adım 5, 3 resimden 2. ASUS X552LAV-BBI5N08 Fan Replacement: adım 5, 3 resimden 3.
      • Remove the four 5.5mm screws located on the hard drive case using a Tri-wing Y1 screwdriver.
      • Slide the hard drive out to the left.
      FixBot'a Sor
      Yorum Ekle
    4. ASUS X552LAV-BBI5N08 Fan Replacement: adım 6, 3 resimden 1. ASUS X552LAV-BBI5N08 Fan Replacement: adım 6, 3 resimden 2. ASUS X552LAV-BBI5N08 Fan Replacement: adım 6, 3 resimden 3.
      • Use opening tool to split keyboard from base of the laptop.
      • Make sure to start from one end and go around the edges.
      • Use Tri-wing Y1 screwdriver to remove two 12mm screws from battery area.
      FixBot'a Sor
      Yorum Ekle
    5. ASUS X552LAV-BBI5N08 Fan Replacement: adım 7, 3 resimden 1. ASUS X552LAV-BBI5N08 Fan Replacement: adım 7, 3 resimden 2. ASUS X552LAV-BBI5N08 Fan Replacement: adım 7, 3 resimden 3.
      • Flip laptop to sit on its bottom.
      • Lift keyboard up by the front edge
      FixBot'a Sor
      Yorum Ekle
    6. ASUS X552LAV-BBI5N08 Fan Replacement: adım 8, 3 resimden 1. ASUS X552LAV-BBI5N08 Fan Replacement: adım 8, 3 resimden 2. ASUS X552LAV-BBI5N08 Fan Replacement: adım 8, 3 resimden 3.
      • Flip up the small locking flap for the two ZIF connectors.
      • Unplug connectors that are keeping keyboard connected
      FixBot'a Sor
      Yorum Ekle
    7. ASUS X552LAV-BBI5N08 Fan Replacement: adım 9, 3 resimden 1. ASUS X552LAV-BBI5N08 Fan Replacement: adım 9, 3 resimden 2. ASUS X552LAV-BBI5N08 Fan Replacement: adım 9, 3 resimden 3.
      • Flip up the locking flap for the ZIF connector.
      • Unplug the connector that is keeping the keyboard connected.
      FixBot'a Sor
      Yorum Ekle
    8. ASUS X552LAV-BBI5N08 Fan Replacement: adım 10, 3 resimden 1. ASUS X552LAV-BBI5N08 Fan Replacement: adım 10, 3 resimden 2. ASUS X552LAV-BBI5N08 Fan Replacement: adım 10, 3 resimden 3.
      • Remove keyboard from laptop.
      • Remove the five 4mm screws (with a Tri-wing Y1 screwdriver) that are both connecting the fan and motherboard.
      • Pull out WiFi from below the cooling fan by lifting the edge nearest to the fan and sliding it towards the fan.
      FixBot'a Sor
      Yorum Ekle
    9. ASUS X552LAV-BBI5N08 Fan Replacement: adım 11, 3 resimden 1. ASUS X552LAV-BBI5N08 Fan Replacement: adım 11, 3 resimden 2. ASUS X552LAV-BBI5N08 Fan Replacement: adım 11, 3 resimden 3.
      • Lift yellow ZIF connector from the top of the motherboard to remove the connector.
      • Lift up motherboard from bottom edge towards the screen.
      FixBot'a Sor
      Yorum Ekle
    10. ASUS X552LAV-BBI5N08 Fan Replacement: adım 12, 2 resimden 1. ASUS X552LAV-BBI5N08 Fan Replacement: adım 12, 2 resimden 2.
      • Unplug the two bundled cable connector from pin sockets below the fan.
      • Remove the motherboard and place on a flat surface.
      • Remove four 4mm screws with a Tri-wing Y1 screwdriver from the CPU.
      FixBot'a Sor
      Yorum Ekle
    11. ASUS X552LAV-BBI5N08 Fan Replacement: adım 13, 2 resimden 1. ASUS X552LAV-BBI5N08 Fan Replacement: adım 13, 2 resimden 2.
      • Disconnect bundled cable connector from the motherboard
      • Remove fan part from the motherboard.
      FixBot'a Sor
      Yorum Ekle
    12. ASUS X552LAV-BBI5N08 Fan Replacement: adım 14, 3 resimden 1. ASUS X552LAV-BBI5N08 Fan Replacement: adım 14, 3 resimden 2. ASUS X552LAV-BBI5N08 Fan Replacement: adım 14, 3 resimden 3.
      • Remove the black tape from the top of the fan radiator.
      • Remove radiator by tilting it down and pulling it out from the fan.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Jason Vo
891 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S17-G1, Boczar Spring 2018 USF Tampa, Team S17-G1, Boczar Spring 2018 üyesi
USFT-BOCZAR-S18S17G1
4 Üyeler
30 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 5
Son 30 gün: 26
Her zaman: 882
