Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Slide the right button to the left.
Hold the left button to the right.
While you hold the left button in position, slide the battery out by pushing it away from you.
Locate the bottom panel. It is at the opposite end of the battery.
Remove the two 12mm screws at the bottom panel with a Tri-wing Y1 screwdriver.
Remove the four 5.5mm screws located on the hard drive case using a Tri-wing Y1 screwdriver.
Slide the hard drive out to the left.
Use opening tool to split keyboard from base of the laptop.
Make sure to start from one end and go around the edges.
Use Tri-wing Y1 screwdriver to remove two 12mm screws from battery area.
Flip laptop to sit on its bottom.
Lift keyboard up by the front edge
Flip up the small locking flap for the two ZIF connectors.
Unplug connectors that are keeping keyboard connected
Flip up the locking flap for the ZIF connector.
Unplug the connector that is keeping the keyboard connected.
Remove keyboard from laptop.
Remove the five 4mm screws (with a Tri-wing Y1 screwdriver) that are both connecting the fan and motherboard.
Pull out WiFi from below the cooling fan by lifting the edge nearest to the fan and sliding it towards the fan.
Lift yellow ZIF connector from the top of the motherboard to remove the connector.
Lift up motherboard from bottom edge towards the screen.
Unplug the two bundled cable connector from pin sockets below the fan.
Remove the motherboard and place on a flat surface.
Remove four 4mm screws with a Tri-wing Y1 screwdriver from the CPU.
Disconnect bundled cable connector from the motherboard
Remove fan part from the motherboard.
Remove the black tape from the top of the fan radiator.
Remove radiator by tilting it down and pulling it out from the fan.
