Ana içeriğe geç
ASUS X552LAV-BBI5N08 Hard Drive Replacement
Neye ihtiyacın var
  1. ASUS X552LAV-BBI5N08 Hard Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Battery is not showed in pictures.
    • Flip the laptop face down.
  2. ASUS X552LAV-BBI5N08 Hard Drive Replacement: adım 2, 3 resimden 1. ASUS X552LAV-BBI5N08 Hard Drive Replacement: adım 2, 3 resimden 2. ASUS X552LAV-BBI5N08 Hard Drive Replacement: adım 2, 3 resimden 3.
    • Slide the right button to the left.
    • Hold the left button to the right.
    • While you hold the left button in position, slide the battery out by pushing it away from you.
  3. ASUS X552LAV-BBI5N08 Hard Drive Replacement, Hard Drive: adım 3, 1 resimden 1.
    • Start by flipping the laptop face down.
    • Locate the bottom panel. It is at the opposite end of the battery.
    • Remove the two 12mm screws at the bottom panel with a Tri-wing Y1 screwdriver.
  4. ASUS X552LAV-BBI5N08 Hard Drive Replacement: adım 4, 3 resimden 1. ASUS X552LAV-BBI5N08 Hard Drive Replacement: adım 4, 3 resimden 2. ASUS X552LAV-BBI5N08 Hard Drive Replacement: adım 4, 3 resimden 3.
    • Remove bottom panel by lifting it up.
    • Locate the hard drive.
    • It is located in the bottom left corner.
  5. ASUS X552LAV-BBI5N08 Hard Drive Replacement: adım 5, 3 resimden 1. ASUS X552LAV-BBI5N08 Hard Drive Replacement: adım 5, 3 resimden 2. ASUS X552LAV-BBI5N08 Hard Drive Replacement: adım 5, 3 resimden 3.
    • Remove the four 5.5mm screws located on the hard drive case using a Tri-wing Y1 screwdriver.
    • Slide the hard drive out to the left.
  6. ASUS X552LAV-BBI5N08 Hard Drive Replacement: adım 6, 2 resimden 1. ASUS X552LAV-BBI5N08 Hard Drive Replacement: adım 6, 2 resimden 2.
    • Lift the hard drive out.
    • Once the hard drive is removed, place the hard drive at a different area.
  7. ASUS X552LAV-BBI5N08 Hard Drive Replacement: adım 7, 3 resimden 1. ASUS X552LAV-BBI5N08 Hard Drive Replacement: adım 7, 3 resimden 2. ASUS X552LAV-BBI5N08 Hard Drive Replacement: adım 7, 3 resimden 3.
    • Place the hard drive on its side.
    • Remove the four 5mm screws from the sides of the case by using a Tri-wing Y1 screwdriver.
    • Lift the hard drive out of the case.
Sonuç
Jason Vo
857 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S17-G1, Boczar Spring 2018 USF Tampa, Team S17-G1, Boczar Spring 2018 üyesi
USFT-BOCZAR-S18S17G1
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 311
