Giriş
This guide will show you how to replace the screen on a ASUS X552LAV-BBI5N08 laptop.
Neye ihtiyacın var
Remove the six 12mm screws located at both the battery area and the bottom panel, with a Tri-wing Y1 screwdriver.
Slide the bottom panel down and lift it up to remove.
Remove the seven 5.5mm screws located at the bottom area with a Tri-wing Y1 screwdriver.
Neredeyse bitti!
Sonuç
