Ana içeriğe geç
ASUS ZENFONE 3 Zoom Back Camera Replacement
Neye ihtiyacın var
  1. ASUS ZENFONE 3 Zoom Back Camera Replacement, Battery: adım 1, 2 resimden 1. ASUS ZENFONE 3 Zoom Back Camera Replacement, Battery: adım 1, 2 resimden 2.
    • Using a pair of tweezers, pull put the SIM card tray and set it to the side.
  2. ASUS ZENFONE 3 Zoom Back Camera Replacement: adım 2, 1 resimden 1.
    • Remove the two 2 mm screws using a Torx T2 screwdriver.
  3. ASUS ZENFONE 3 Zoom Back Camera Replacement: adım 3, 2 resimden 1. ASUS ZENFONE 3 Zoom Back Camera Replacement: adım 3, 2 resimden 2.
    • Insert a prying tool between the screen and the metal backing of the phone at the bottom to remove backing from phone.
    • There will be a thin film connecting the two pieces. You do not need to remove this. Just fold the two pieces apart with the inside facing up.
  4. ASUS ZENFONE 3 Zoom Back Camera Replacement: adım 4, 1 resimden 1.
    • Remove the two 3 mm screws, using the Phillips #00 screwdriver, on the silver band at the top of the battery and remove the band.
  5. ASUS ZENFONE 3 Zoom Back Camera Replacement: adım 5, 1 resimden 1.
    • Peel back the silver tape.
  6. ASUS ZENFONE 3 Zoom Back Camera Replacement: adım 6, 1 resimden 1.
    • Disconnect the battery connections.
  7. ASUS ZENFONE 3 Zoom Back Camera Replacement: adım 7, 1 resimden 1.
    • Pry and remove the battery.
    • The underside of the battery is adhesive so make sure to pry the battery off gently.
  8. ASUS ZENFONE 3 Zoom Back Camera Replacement, Back Camera: adım 8, 3 resimden 1. ASUS ZENFONE 3 Zoom Back Camera Replacement, Back Camera: adım 8, 3 resimden 2. ASUS ZENFONE 3 Zoom Back Camera Replacement, Back Camera: adım 8, 3 resimden 3.
    • Remove the 3 mm screws, using the Phillips #00 screwdriver, from the black plastic piece at the top on the right side.
  9. ASUS ZENFONE 3 Zoom Back Camera Replacement: adım 9, 1 resimden 1.
    • Remove the 3 mm screws, using the Phillips #00 screwdriver, from the metal piece around the camera.
  10. ASUS ZENFONE 3 Zoom Back Camera Replacement: adım 10, 2 resimden 1. ASUS ZENFONE 3 Zoom Back Camera Replacement: adım 10, 2 resimden 2.
    • Remove the 3 mm circuit board screws, using the Phillips #00 screwdriver.
  11. ASUS ZENFONE 3 Zoom Back Camera Replacement: adım 11, 3 resimden 1. ASUS ZENFONE 3 Zoom Back Camera Replacement: adım 11, 3 resimden 2. ASUS ZENFONE 3 Zoom Back Camera Replacement: adım 11, 3 resimden 3.
    • Unplug the two wires at the bottom of the circuit board.
  12. ASUS ZENFONE 3 Zoom Back Camera Replacement: adım 12, 1 resimden 1.
    • Remove the circuit board.
  13. ASUS ZENFONE 3 Zoom Back Camera Replacement: adım 13, 2 resimden 1. ASUS ZENFONE 3 Zoom Back Camera Replacement: adım 13, 2 resimden 2.
    • Unplug the camera.
Sonuç
Henry Barrett
546 İtibar
4 adet Kılavuz yazıldı
Bir Yorum
Excellent article. Just one question; who is selling this camera?
Hazem Tawfik - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 1,164
