Giriş
This guide will demonstrate how to replace the Speaker/Charger Port/Headphone Jack of a Zenfone 3. This may be necessary if these functions no longer work as normal. For this guide, you will need the tweezers, Torx T2 screwdriver, a prying tool, and the Phillips #00 screwdriver.
  1. Using a pair of tweezers, pull put the SIM card tray and set it to the side. Using a pair of tweezers, pull put the SIM card tray and set it to the side.
    • Using a pair of tweezers, pull put the SIM card tray and set it to the side.
  2. Remove the two 2 mm screws using a Torx T2 screwdriver.
    • Remove the two 2 mm screws using a Torx T2 screwdriver.
  3. Insert a prying tool between the screen and the metal backing of the phone at the bottom to remove backing from phone. There will be a thin film connecting the two pieces. You do not need to remove this. Just fold the two pieces apart with the inside facing up.
    • Insert a prying tool between the screen and the metal backing of the phone at the bottom to remove backing from phone.
    • There will be a thin film connecting the two pieces. You do not need to remove this. Just fold the two pieces apart with the inside facing up.
  4. Remove the two 3 mm screws, using the Phillips #00 screwdriver, on the silver band at the top of the battery and remove the band.
    • Remove the two 3 mm screws, using the Phillips #00 screwdriver, on the silver band at the top of the battery and remove the band.
  5. Pro Tech Toolkit içeren veya $100tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  6. Peel back the silver tape.
    • Peel back the silver tape.
  7. Disconnect the battery connections.
    • Disconnect the battery connections.
  8. Pry and remove the battery.
    • Pry and remove the battery.
    • The underside of the battery is adhesive so make sure to pry the battery off gently.
  9. Remove all screws 3mm, using the Phillips #00 screwdriver, at the bottom of the device. Remove all screws 3mm, using the Phillips #00 screwdriver, at the bottom of the device. Remove all screws 3mm, using the Phillips #00 screwdriver, at the bottom of the device.
    • Remove all screws 3mm, using the Phillips #00 screwdriver, at the bottom of the device.
  10. Remove the black piece.
    • Remove the black piece.
  11. Unplug the wires. Unplug the wires.
    • Unplug the wires.
  12. Using the pry tool, pry up the circular piece and remove the board. Using the pry tool, pry up the circular piece and remove the board. Using the pry tool, pry up the circular piece and remove the board.
    • Using the pry tool, pry up the circular piece and remove the board.
Sonuç
Henry Barrett
480 İtibar
4 adet Kılavuz yazıldı
0 Yorum
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 Gün: 10
Son 30 Gün: 35
Her zaman: 131
