Ana içeriğe geç
ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement
Neye ihtiyacın var
  1. ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement, Back Cover: adım 1, 2 resimden 1. ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement, Back Cover: adım 1, 2 resimden 2.
    • Flip the laptop over so the model stickers face the ceiling.
  2. ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement: adım 2, 2 resimden 1. ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement: adım 2, 2 resimden 2.
    • Remove eleven 7mm Phillips #00 screws that secure the back cover.
    • Two screws are under the rubber pad.
  3. ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement: adım 3, 2 resimden 1. ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement: adım 3, 2 resimden 2.
    • Using a spudger, carefully remove the back cover.
  4. ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement, Battery: adım 4, 2 resimden 1. ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement, Battery: adım 4, 2 resimden 2.
    • Remove the six 3mm Phillips #00 screws holding the battery in place.
  5. ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement: adım 5, 2 resimden 1. ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement: adım 5, 2 resimden 2.
    • Disconnect the battery wires from the motherboard by pulling on the black tab using a spudger or your hands.
  6. ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement: adım 6, 1 resimden 1.
    • Carefully lift the battery up and out of the laptop.
  7. ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement, Hard Drive: adım 7, 3 resimden 1. ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement, Hard Drive: adım 7, 3 resimden 2. ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement, Hard Drive: adım 7, 3 resimden 3.
    • Remove four 3 mm Phillips screws (two on each side) holding the hard drive in the frame
  8. ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement: adım 8, 2 resimden 1. ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement: adım 8, 2 resimden 2.
    • Grip the side of the hard drive and slide it out of the device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Joshua Letizia
193 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S4-G4, Saloman Fall 2019 UMass Dartmouth, Team S4-G4, Saloman Fall 2019 üyesi
UMASSD-SALOMAN-F19S4G4
3 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 9
Her zaman: 551
