Ana içeriğe geç
ASUS ZenBook UX302LA-BHI5T08 RAM Replacement
Neye ihtiyacın var
  1. ASUS ZenBook UX302LA-BHI5T08 RAM Replacement, Back Cover: adım 1, 2 resimden 1. ASUS ZenBook UX302LA-BHI5T08 RAM Replacement, Back Cover: adım 1, 2 resimden 2.
    • Flip the laptop over so the model stickers face the ceiling.
  2. ASUS ZenBook UX302LA-BHI5T08 RAM Replacement: adım 2, 2 resimden 1. ASUS ZenBook UX302LA-BHI5T08 RAM Replacement: adım 2, 2 resimden 2.
    • Remove eleven 7mm Phillips #00 screws that secure the back cover.
    • Two screws are under the rubber pad.
  3. ASUS ZenBook UX302LA-BHI5T08 RAM Replacement: adım 3, 2 resimden 1. ASUS ZenBook UX302LA-BHI5T08 RAM Replacement: adım 3, 2 resimden 2.
    • Using a spudger, carefully remove the back cover.
  4. ASUS ZenBook UX302LA-BHI5T08 RAM Replacement, RAM: adım 4, 3 resimden 1. ASUS ZenBook UX302LA-BHI5T08 RAM Replacement, RAM: adım 4, 3 resimden 2. ASUS ZenBook UX302LA-BHI5T08 RAM Replacement, RAM: adım 4, 3 resimden 3.
    • To unlock the RAM, simply move the metal brackets using your finger.
    • When the RAM is unlocked, it will elevate itself.
  5. ASUS ZenBook UX302LA-BHI5T08 RAM Replacement: adım 5, 2 resimden 1. ASUS ZenBook UX302LA-BHI5T08 RAM Replacement: adım 5, 2 resimden 2.
    • Remove the RAM from the laptop.
  6. ASUS ZenBook UX302LA-BHI5T08 RAM Replacement: adım 6, 1 resimden 1.
    • To insert the new RAM, line up the hole on the RAM stick and slot.
    • Next, push the RAM down gently. It should make a snap sound.
    • Do not use too much force as it can break the RAM.
Sonuç
Jin Feng Lin
330 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S4-G4, Saloman Fall 2019 UMass Dartmouth, Team S4-G4, Saloman Fall 2019 üyesi
UMASSD-SALOMAN-F19S4G4
3 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 449
