Giriş
This is a guide outlining how to remove and replace the daughter board (also known secondary board). Make sure the battery is completely removed before working on the daughter board as to prevent shorts in the circuitry As a precautions ground yourself to prevent frying the internal components. Also make sure to keep track of screws and label them.
Neye ihtiyacın var
Use the plastic tool to pry between the silver bezel and the back case
Work the tool around the device to free the back case
To remove the ribbon cables, lift up the white retaining flap on the ZIF Connectors with a plastic pry tool
5 farklı kişi bu kılavuzu tamamladı.
4 Yorum
Thanks for helping me fix my beloved Zenpad!
Karen, where did you get the replacement daughter board? I can’t find one anywhere! - Christine
Bought it here:
https://www.asusparts.eu/en/Asus-90NP01M...
This is Part Number: 32YU1CB0000,
“ASUSparts” internal part number: 90NP01M0-R10010
Please clarify Step 9 - where exactly is the warranty tape that needs to be cut?
I have this unit and it stopped charging and stopped holding charge- I do not want to buy another unit as I invested a LOT of time in setting this one up…
Thanks
vshulyaker@gmail.com
