Ana içeriğe geç
ASUS ZenPad S 8.0 Front Facing Camera Replacement
Neye ihtiyacın var
    1. ASUS ZenPad S 8.0 Front Facing Camera Replacement, Rear Cover Removal: adım 1, 3 resimden 1. ASUS ZenPad S 8.0 Front Facing Camera Replacement, Rear Cover Removal: adım 1, 3 resimden 2. ASUS ZenPad S 8.0 Front Facing Camera Replacement, Rear Cover Removal: adım 1, 3 resimden 3.
      • if present, remove the MicroSD card before disassembly. Failure to remove could lead to damage to the MicroSD card , rear cover, or MicroSD card slot.
      • Use the plastic tool to pry between the silver bezel and the back case
      • Work the tool around the device to free the back case
      FixBot'a Sor
      Yorum Ekle
    2. ASUS ZenPad S 8.0 Front Facing Camera Replacement: adım 2, 2 resimden 1. ASUS ZenPad S 8.0 Front Facing Camera Replacement: adım 2, 2 resimden 2.
      • Remove the ribbon cables by lifting up the white retaining flap on the ZIF connectors, then pulling the ribbon cable away.
      • Do not kink the ribbon cables as they can break easily
      FixBot'a Sor
      Yorum Ekle
    3. ASUS ZenPad S 8.0 Front Facing Camera Replacement: adım 3, 3 resimden 1. ASUS ZenPad S 8.0 Front Facing Camera Replacement: adım 3, 3 resimden 2. ASUS ZenPad S 8.0 Front Facing Camera Replacement: adım 3, 3 resimden 3.
      • Remove the battery connector by prying it up away from the device using 2 plastic pry tools
      FixBot'a Sor
      Yorum Ekle
    4. ASUS ZenPad S 8.0 Front Facing Camera Replacement: adım 4, 2 resimden 1. ASUS ZenPad S 8.0 Front Facing Camera Replacement: adım 4, 2 resimden 2.
      • Remove all 9 of the 1.5mm #00 Philips screws
      • Gently lift the battery out of the device
      • Use an opening pick or similar tool to separate the adhesive on the bottom and top of the battery.
      FixBot'a Sor
      Yorum Ekle
    1. ASUS ZenPad S 8.0 Front Facing Camera Replacement, Front Facing Camera: adım 5, 3 resimden 1. ASUS ZenPad S 8.0 Front Facing Camera Replacement, Front Facing Camera: adım 5, 3 resimden 2. ASUS ZenPad S 8.0 Front Facing Camera Replacement, Front Facing Camera: adım 5, 3 resimden 3.
      • Use a plastic opening tool to lift the black retaining flap on the ZIF Connector
      FixBot'a Sor
      Yorum Ekle
    2. ASUS ZenPad S 8.0 Front Facing Camera Replacement: adım 6, 1 resimden 1.
      Bu adımda kullanılan alet:
      • Use a tweezers to lift out the camera
      • If you lifted the latch for the ribbon cable then it should come out with little resistance.
      FixBot'a Sor
      Yorum Ekle
Sonuç
John Astfanous
987 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 2-2, Cagle Fall 2016 USF Tampa, Team 2-2, Cagle Fall 2016 üyesi
USFT-CAGLE-F16S2G2
4 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 23
Her zaman: 1,648
