Ana içeriğe geç
ASUS ZenPad S 8.0 Speakers Replacement
Neye ihtiyacın var
  1. ASUS ZenPad S 8.0 Speakers Replacement, Rear Cover Removal: adım 1, 3 resimden 1. ASUS ZenPad S 8.0 Speakers Replacement, Rear Cover Removal: adım 1, 3 resimden 2. ASUS ZenPad S 8.0 Speakers Replacement, Rear Cover Removal: adım 1, 3 resimden 3.
    • if present, remove the MicroSD card before disassembly. Failure to remove could lead to damage to the MicroSD card , rear cover, or MicroSD card slot.
    • Use the plastic tool to pry between the silver bezel and the back case
    • Work the tool around the device to free the back case
  2. ASUS ZenPad S 8.0 Speakers Replacement: adım 2, 2 resimden 1. ASUS ZenPad S 8.0 Speakers Replacement: adım 2, 2 resimden 2.
    • Remove the ribbon cables by lifting up the white retaining flap on the ZIF connectors, then pulling the ribbon cable away.
    • Do not kink the ribbon cables as they can break easily
  3. ASUS ZenPad S 8.0 Speakers Replacement: adım 3, 3 resimden 1. ASUS ZenPad S 8.0 Speakers Replacement: adım 3, 3 resimden 2. ASUS ZenPad S 8.0 Speakers Replacement: adım 3, 3 resimden 3.
    • Remove the battery connector by prying it up away from the device using 2 plastic pry tools
  4. ASUS ZenPad S 8.0 Speakers Replacement: adım 4, 2 resimden 1. ASUS ZenPad S 8.0 Speakers Replacement: adım 4, 2 resimden 2.
    • Remove all 9 of the 1.5mm #00 Philips screws
    • Gently lift the battery out of the device
    • Use an opening pick or similar tool to separate the adhesive on the bottom and top of the battery.
  5. ASUS ZenPad S 8.0 Speakers Replacement, Front Facing Camera: adım 5, 3 resimden 1. ASUS ZenPad S 8.0 Speakers Replacement, Front Facing Camera: adım 5, 3 resimden 2. ASUS ZenPad S 8.0 Speakers Replacement, Front Facing Camera: adım 5, 3 resimden 3.
    • Use a plastic opening tool to lift the black retaining flap on the ZIF Connector
  6. ASUS ZenPad S 8.0 Speakers Replacement: adım 6, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Use a tweezers to lift out the camera
    • If you lifted the latch for the ribbon cable then it should come out with little resistance.
  7. ASUS ZenPad S 8.0 Speakers Replacement, Motherboard: adım 7, 2 resimden 1. ASUS ZenPad S 8.0 Speakers Replacement, Motherboard: adım 7, 2 resimden 2.
    • Using the plastic prying tool, lift the small retaining flap on the ZIF Connectors holding the ribbon cables to the motherboard
    • The removing of the ribbon cable is done in the same way as the front facing camera.
  8. ASUS ZenPad S 8.0 Speakers Replacement: adım 8, 3 resimden 1. ASUS ZenPad S 8.0 Speakers Replacement: adım 8, 3 resimden 2. ASUS ZenPad S 8.0 Speakers Replacement: adım 8, 3 resimden 3.
    • Using the tweezers remove the connector gently from the yellow slot
    • Gently peel up the tape until is is completely released from the motherboard
  9. ASUS ZenPad S 8.0 Speakers Replacement: adım 9, 2 resimden 1. ASUS ZenPad S 8.0 Speakers Replacement: adım 9, 2 resimden 2.
    • Cut the warranty tape connecting the motherboard to the metal plate under the battery
  10. ASUS ZenPad S 8.0 Speakers Replacement: adım 10, 1 resimden 1.
    • Using the #00 Phillips head screwdriver, remove the remaining 1.5mm screws in the motherboard
  11. ASUS ZenPad S 8.0 Speakers Replacement: adım 11, 1 resimden 1.
    • Gently lift the motherboard from your device
  12. ASUS ZenPad S 8.0 Speakers Replacement, Daughter Board: adım 12, 3 resimden 1. ASUS ZenPad S 8.0 Speakers Replacement, Daughter Board: adım 12, 3 resimden 2. ASUS ZenPad S 8.0 Speakers Replacement, Daughter Board: adım 12, 3 resimden 3.
    • To remove the ribbon cables, lift up the white retaining flap on the ZIF Connectors with a plastic pry tool
  13. ASUS ZenPad S 8.0 Speakers Replacement: adım 13, 3 resimden 1. ASUS ZenPad S 8.0 Speakers Replacement: adım 13, 3 resimden 2. ASUS ZenPad S 8.0 Speakers Replacement: adım 13, 3 resimden 3.
    • Using the tweezers gently pull off the tape over the ribbon cable
  14. ASUS ZenPad S 8.0 Speakers Replacement: adım 14, 2 resimden 1. ASUS ZenPad S 8.0 Speakers Replacement: adım 14, 2 resimden 2.
    • Using the tweezers gently pull the ribbon cable out from from the connector.
  15. ASUS ZenPad S 8.0 Speakers Replacement: adım 15, 3 resimden 1. ASUS ZenPad S 8.0 Speakers Replacement: adım 15, 3 resimden 2. ASUS ZenPad S 8.0 Speakers Replacement: adım 15, 3 resimden 3.
    • Using the tweezers gently remove the connector from the yellow slot
  16. ASUS ZenPad S 8.0 Speakers Replacement: adım 16, 2 resimden 1. ASUS ZenPad S 8.0 Speakers Replacement: adım 16, 2 resimden 2.
    • Cut the warranty tape connecting the daughter board to the metal plate under the battery
  17. ASUS ZenPad S 8.0 Speakers Replacement: adım 17, 3 resimden 1. ASUS ZenPad S 8.0 Speakers Replacement: adım 17, 3 resimden 2. ASUS ZenPad S 8.0 Speakers Replacement: adım 17, 3 resimden 3.
    • Using the #00 Phillips head screwdriver, remove the remaining 1.5mm screws in the daughter board
    • Gently lift the daughter board from the device
  18. ASUS ZenPad S 8.0 Speakers Replacement, Speakers: adım 18, 2 resimden 1. ASUS ZenPad S 8.0 Speakers Replacement, Speakers: adım 18, 2 resimden 2.
    • Gently lift up the speaker to remove it from the device
  19. ASUS ZenPad S 8.0 Speakers Replacement: adım 19, 3 resimden 1. ASUS ZenPad S 8.0 Speakers Replacement: adım 19, 3 resimden 2. ASUS ZenPad S 8.0 Speakers Replacement: adım 19, 3 resimden 3.
    • Using the #00 Phillips head screwdriver, remove the 1.5mm screws
    • Gently lift up the second speaker to remove it from the device
Sonuç
John Astfanous
987 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 2-2, Cagle Fall 2016 USF Tampa, Team 2-2, Cagle Fall 2016 üyesi
USFT-CAGLE-F16S2G2
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 1,009
