Ana içeriğe geç
ASUS ZenWatch Battery Replacement
Neye ihtiyacın var
    1. ASUS ZenWatch Battery Replacement, Watch Strap Removal: adım 1, 2 resimden 1. ASUS ZenWatch Battery Replacement, Watch Strap Removal: adım 1, 2 resimden 2.
      • On the strap there is a knob. Sliding this knob towards the opposite side of the strap releases the tension on the spring bar, allowing you to pull the strap out..
      FixBot'a Sor
      Yorum Ekle
    1. ASUS ZenWatch Battery Replacement, Battery: adım 2, 3 resimden 1. ASUS ZenWatch Battery Replacement, Battery: adım 2, 3 resimden 2. ASUS ZenWatch Battery Replacement, Battery: adım 2, 3 resimden 3.
      • Use the T5 Torx driver to remove the four screws on the case.
      • Use the magnetic pad to keep all your parts easily contained!
      • The case will pry easily off with just gentle hand pressure
      FixBot'a Sor
      Yorum Ekle
    2. ASUS ZenWatch Battery Replacement: adım 3, 2 resimden 1. ASUS ZenWatch Battery Replacement: adım 3, 2 resimden 2.
      Bu adımda kullanılan alet:
      • Using the tweezers, gently remove the fabric protecting the battery connection.
      • Take care when removing the fabric. Too much force may damage the contact with the metal tweezers.
      • Use the heavy duty spudger to gently push the contact towards the top of the case.
      FixBot'a Sor
      Yorum Ekle
    3. ASUS ZenWatch Battery Replacement: adım 4, 3 resimden 1. ASUS ZenWatch Battery Replacement: adım 4, 3 resimden 2. ASUS ZenWatch Battery Replacement: adım 4, 3 resimden 3.
      • Gently pry the battery up with the plastic pry tools
      FixBot'a Sor
      Yorum Ekle
Sonuç
13 farklı kişi bu kılavuzu tamamladı.
Wayne McClure
961 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-3, Sullivan Spring 2016 USF Tampa, Team 1-3, Sullivan Spring 2016 üyesi
USFT-SULLIVAN-S16S1G3
4 Üyeler
7 adet Kılavuz yazıldı
6Kılavuz Yorumları
Where could i find the modul replacement for asus zenwatch edition (1st editio) the chip body…thanks :) Dave
Davy Jones - Yanıt Paylaş
Dónde puedo adquirir esta batería en Colombia
Jhon Jairo Piza Puerta - Yanıt Paylaş
I want to find a battery for zenwatch 1 plz help i still have a fully functioning zenwatch I don’t want to waste it. (pref na or even better Canadian the shipping is murder)
wing_0_delta - Yanıt Paylaş
Hi
im looking for a battery für Asus Viviwatch. Is ist the same as in ZenWatch?
mhoechtl - Yanıt Paylaş
Looking to get zenwatch 1 battery. Any source recommended by anyone?
fine_pears - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 15
Son 30 gün: 69
Her zaman: 15,173
