Ana içeriğe geç
ASUS ZenWatch Charging Cradle Circuit board Replacement
Neye ihtiyacın var
  1. ASUS ZenWatch Charging Cradle Circuit board Replacement, Charging Cradle Circuit board: adım 1, 3 resimden 1. ASUS ZenWatch Charging Cradle Circuit board Replacement, Charging Cradle Circuit board: adım 1, 3 resimden 2. ASUS ZenWatch Charging Cradle Circuit board Replacement, Charging Cradle Circuit board: adım 1, 3 resimden 3.
    • Using a metal spudger gently pry the plastic outer case apart
    • Pry open a little bit on each side before trying to open fully
  2. ASUS ZenWatch Charging Cradle Circuit board Replacement: adım 2, 3 resimden 1. ASUS ZenWatch Charging Cradle Circuit board Replacement: adım 2, 3 resimden 2. ASUS ZenWatch Charging Cradle Circuit board Replacement: adım 2, 3 resimden 3.
    • Use the PH0 sized Phillips screwdriver to remove the three screws (2mm) holding the board to the cradle.
    • Gently pry up with your hands to pull the board off.
    • Don't grab directly on the USB port as you may loosen or bust the connections.
Sonuç
Wayne McClure
961 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-3, Sullivan Spring 2016 USF Tampa, Team 1-3, Sullivan Spring 2016 üyesi
USFT-SULLIVAN-S16S1G3
4 Üyeler
7 adet Kılavuz yazıldı
Bir Yorum
If you had listed what components were on the board or at least taken a picture of the other side of the board, I might have given you some points.
Nate Fansler - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 18
Her zaman: 2,881
