Ana içeriğe geç
AT-LP120-USB Start/Stop Button Replacement
Neye ihtiyacın var
  1. AT-LP120-USB Start/Stop Button Replacement, Preparation: adım 1, 1 resimden 1.
    • Disconnect your turntable from power and audio.
    • Move the turntable to a clear flat surface.
  2. AT-LP120-USB Start/Stop Button Replacement, Disassembly: Remove Necessary Accessories: adım 2, 1 resimden 1.
    • In this step, we are removing the necessary accessories to mitigate the possibility of damage in the upcoming steps.
    • Engage the tone arm clamp
    • Remove 45 adaptor.
    • Remove slipmat.
    • Remove platter by using the two circular holes and pulling vertically from the top of the turntable.
    • Remove the counterweight by unscrewing the rear clockwise.
  3. AT-LP120-USB Start/Stop Button Replacement, Disassembly: Tie Down Tone Arm: adım 3, 1 resimden 1.
    • This step is an extra precaution in case the tone arm clamp becomes loose during handling.
    • Tie down the tone arm using a twist tie/zip tie.
    • The next step involves flipping the turntable onto the the dust cover. At this time it would be best to find a soft surface (ie. cloth, foam, etc.) to place it on to mitigate damage to the dust cover.
  4. AT-LP120-USB Start/Stop Button Replacement, Disassembly: Remove Screws: adım 4, 1 resimden 1.
    • Place on soft surface (ie. cloth, foam, etc) to mitigate risk of damaging the dust cover.
    • Carefully flip the turntable onto the dust cover.
    • Remove 8 screws.
    • Each screw is accompanied by one brass bushing. These bushings might come out still attached to the screws, or will stay inside the turntable.
  5. AT-LP120-USB Start/Stop Button Replacement, Disassembly: Remove Bottom Cover: adım 5, 3 resimden 1. AT-LP120-USB Start/Stop Button Replacement, Disassembly: Remove Bottom Cover: adım 5, 3 resimden 2. AT-LP120-USB Start/Stop Button Replacement, Disassembly: Remove Bottom Cover: adım 5, 3 resimden 3.
    • Spin the turntable so that the rear is facing you.
    • Lift off the bottom cover.
    • Depending on manufacturer date, you may need to tilt the bottom cover to pull it away from the ports/switches.
    • Remove the hinges if they do not come out of the dust cover when lifting.
    • As you pull the bottom cover off, the RCA cables will be removed through this hole.
  6. AT-LP120-USB Start/Stop Button Replacement, Disassembly: Locate The Button: adım 6, 3 resimden 1. AT-LP120-USB Start/Stop Button Replacement, Disassembly: Locate The Button: adım 6, 3 resimden 2. AT-LP120-USB Start/Stop Button Replacement, Disassembly: Locate The Button: adım 6, 3 resimden 3.
    • Spin the turntable back around such that the front is closest to you.
    • Locate and collect the 8 brass bushings if they did not come out with the screws.
    • Slide the bushings to the head of each screw and set aside for later.
    • The button that is being removed can be located here.
  7. AT-LP120-USB Start/Stop Button Replacement, Replacement: Removing Clamp and Washer: adım 7, 3 resimden 1. AT-LP120-USB Start/Stop Button Replacement, Replacement: Removing Clamp and Washer: adım 7, 3 resimden 2. AT-LP120-USB Start/Stop Button Replacement, Replacement: Removing Clamp and Washer: adım 7, 3 resimden 3.
    • Adjust the turntable on top of the dust cover such that the button is protruding from the PCB.
    • Use a pair of tweezers or needle-nose pliers to remove the silver clamp.
    • The clamp requires a bit of force to be pulled off from the post.
    • Remove the black felt washer from the post.
    • Do not dispose of any pieces that come off of the button as these will be used on the replacement button.
  8. AT-LP120-USB Start/Stop Button Replacement, Replacement: Removing The Button: adım 8, 3 resimden 1. AT-LP120-USB Start/Stop Button Replacement, Replacement: Removing The Button: adım 8, 3 resimden 2. AT-LP120-USB Start/Stop Button Replacement, Replacement: Removing The Button: adım 8, 3 resimden 3.
    • The button is now loose and is able to be removed.
    • Adjust the turntable so the dust cover is no longer holding the button up.
    • Remove the button and spring if it did not fall from adjusting the turntable.
    • Remove the spring and black felt washer from the button shaft.
    • If the spring and/or black felt washer are not attached to the button upon removal they are likely stuck near where the button was removed from.
  9. AT-LP120-USB Start/Stop Button Replacement, Replacement: Configuring The New Button: adım 9, 1 resimden 1.
    • Locate your replacement button and place it such that the black plastic post is closest to you.
    • Keeping the button in this orientation for the remainder of the repair will ensure the correct orientation upon completion.
    • Slide the black felt washer down to the base of the shaft.
    • Position the spring around the shaft in-between the small plastic posts.
  10. AT-LP120-USB Start/Stop Button Replacement, Replacement: Inserting And Securing The Button: adım 10, 2 resimden 1. AT-LP120-USB Start/Stop Button Replacement, Replacement: Inserting And Securing The Button: adım 10, 2 resimden 2.
    • Insert the button back into the base of the turntable with the small highlighted post from Step 9 closest to you.
    • Slide the black felt washer onto the shaft of the new button.
    • Press the clamp back into the grooved portion of the shaft.
    • Attaching the clamp will require some force. The technicians normally use the flat handle side of their tweezers to push the clamp into place.
  11. AT-LP120-USB Start/Stop Button Replacement, Reassembly: Placing Bottom Cover: adım 11, 3 resimden 1. AT-LP120-USB Start/Stop Button Replacement, Reassembly: Placing Bottom Cover: adım 11, 3 resimden 2. AT-LP120-USB Start/Stop Button Replacement, Reassembly: Placing Bottom Cover: adım 11, 3 resimden 3.
    • Spin the turntable back around such that the rear is facing you.
    • Place the hinges back into the dust cover.
    • Press this part of the hinge so the hinge is in a vertical position.
    • Locate the bottom cover, and route the RCA cables com from the turntable through this hole.
    • Place the bottom cover onto the turntable such that the dust cover hinges are inserted into their respective brackets, and all ports are visible.
    • Depending on manufacturer date, you may need to tilt the bottom cover and insert the ports/switches before re-attaching the hinges and dust cover.
  12. AT-LP120-USB Start/Stop Button Replacement, Reassembly: Securing Bottom Cover: adım 12, 1 resimden 1.
    • Insert the 8 screws with the brass bushings attached into the bottom cover.
    • Brass bushing placement on the screw is shown in Step 6
    • The turntable is now reassembled.
Sonuç
If the motor continues to have no reaction to pressing the start/stop button after reconnecting the turntable to power and reattaching the platter, the issue is likely caused by a faulty motor.
For further technical assistance, please contact service@atus.com or one of the technicians at (330)686-2600 ext.5004
~Monday-Friday 8:00am to 5:00pm~
Bir başkası bu kılavuzu tamamladı.
Ekli Belgeler
Anthony @ ATUS
1.045 İtibar
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 28
Her zaman: 35
