Ana içeriğe geç
AT-LP60X Belt Installation
Neye ihtiyacın var
  1. AT-LP60X Belt Installation, Setup: adım 1, 3 resimden 1. AT-LP60X Belt Installation, Setup: adım 1, 3 resimden 2. AT-LP60X Belt Installation, Setup: adım 1, 3 resimden 3.
    • Disconnect the power from the turntable.
    • Raise the dust cover.
  2. AT-LP60X Belt Installation, Removing Platter: adım 2, 2 resimden 1. AT-LP60X Belt Installation, Removing Platter: adım 2, 2 resimden 2.
    • Remove the slipmat from the platter.
    • Pull the platter off by lifting vertically from the two circular holes.
  3. AT-LP60X Belt Installation, Mount The Belt To Platter: adım 3, 1 resimden 1.
    • Locate the belt.
    • Flip the platter upside-down and place the belt around the inner ring of the platter.
  4. AT-LP60X Belt Installation, Mounting Platter and Belt: adım 4, 3 resimden 1. AT-LP60X Belt Installation, Mounting Platter and Belt: adım 4, 3 resimden 2. AT-LP60X Belt Installation, Mounting Platter and Belt: adım 4, 3 resimden 3.
    • Place the platter back on the center spindle.
    • Spin the platter such that the gold pulley of the motor is showing.
    • Stretch the belt from the platter around the gold pulley of the motor.
  5. AT-LP60X Belt Installation, Preform Mechanical Reset: adım 5, 3 resimden 1. AT-LP60X Belt Installation, Preform Mechanical Reset: adım 5, 3 resimden 2. AT-LP60X Belt Installation, Preform Mechanical Reset: adım 5, 3 resimden 3.
    • Place the slipmat back onto the platter, and press the STOP button.
    • Using your right hand, secure the tone arm in place.
    • [OPTIONAL] Use a twist tie and the built in hook.
    • While the tone arm is secured, use your left hand to slowly spin the platter 10 times clockwise.
    • You should hear a few clicks and pops.
  6. AT-LP60X Belt Installation, Reconnect Power: adım 6, 1 resimden 1.
    • Remove the twist tie if used to secure the tone arm from Step 5.
    • Reconnect the power supply.
    • The belt installation procedure is now complete - you are ready to try a record!
  7. AT-LP60X Belt Installation, Common Mistakes: adım 7, 2 resimden 1. AT-LP60X Belt Installation, Common Mistakes: adım 7, 2 resimden 2.
    • Any twists while installing the belt will cause improper operation.
    • The belt should NOT be connected to this white post.
    • The belt should NOT be connected to the base of the turntable.
    • The belt should ONLY make contact with the bottom of the platter and the gold pulley of the motor.
Sonuç
If this guide does not fix the issue of the platter not spinning, the following issues could be present:
  1. Faulty AC Adaptor - Can be purchased here.
  2. Faulty Diode (D01) - Requires soldering (repair guide can be provided upon request: service@atus.com). Part Number: 576-SMAJ13A
  3. Faulty Motor - Requires soldering (repair guide can be provided upon request: service@atus.com). Part Number: 704-F706-7303
To send your turntable in for service, please follow the necessary steps from our website.
Feel free to contact one of our technicians for further assistance at (330)686-2600 ext.5004
2 farklı kişi bu kılavuzu tamamladı.
Ekli Belgeler
Anthony @ ATUS
1.195 İtibar
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 48
Son 30 gün: 254
Her zaman: 2,015
