Ana içeriğe geç
Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
ATT CL2940 Buttons and/or Keypad Replacement
Neye ihtiyacın var
  1. ATT CL2940 Buttons and/or Keypad Replacement, Back Panel: adım 1, 3 resimden 1. ATT CL2940 Buttons and/or Keypad Replacement, Back Panel: adım 1, 3 resimden 2. ATT CL2940 Buttons and/or Keypad Replacement, Back Panel: adım 1, 3 resimden 3.
    • Remove five 9.5 mm Phillips #1 screws from the back panel of the phone.
  2. ATT CL2940 Buttons and/or Keypad Replacement: adım 2, 3 resimden 1. ATT CL2940 Buttons and/or Keypad Replacement: adım 2, 3 resimden 2. ATT CL2940 Buttons and/or Keypad Replacement: adım 2, 3 resimden 3.
    • Slide the metal spudger into the crack and continue around to the front panel of the phone.
    • Be careful not to break the clips that hold the back panel to the front panel.
  3. ATT CL2940 Buttons and/or Keypad Replacement: adım 3, 1 resimden 1.
    • When setting the back panel down, be careful to not rip any of the wires off of the internal components.
  4. ATT CL2940 Buttons and/or Keypad Replacement, Buttons and/or Keypad: adım 4, 2 resimden 1. ATT CL2940 Buttons and/or Keypad Replacement, Buttons and/or Keypad: adım 4, 2 resimden 2.
    • Unscrew five 5.6 mm screws on top level, yellow motherboard.
  5. ATT CL2940 Buttons and/or Keypad Replacement: adım 5, 3 resimden 1. ATT CL2940 Buttons and/or Keypad Replacement: adım 5, 3 resimden 2. ATT CL2940 Buttons and/or Keypad Replacement: adım 5, 3 resimden 3.
    • Lift the top level Motherboard in order to get to the lower level Motherboard.
  6. ATT CL2940 Buttons and/or Keypad Replacement: adım 6, 2 resimden 1. ATT CL2940 Buttons and/or Keypad Replacement: adım 6, 2 resimden 2.
    • Unscrew the 5.6 mm screw on the clip behind the Screen as shown.
  7. ATT CL2940 Buttons and/or Keypad Replacement: adım 7, 2 resimden 1. ATT CL2940 Buttons and/or Keypad Replacement: adım 7, 2 resimden 2.
    • Unscrew five 5.6 mm screws on the lower level Motherboard.
    • Keep the screws for the upper and lower level motherboard separated.
  8. ATT CL2940 Buttons and/or Keypad Replacement: adım 8, 2 resimden 1. ATT CL2940 Buttons and/or Keypad Replacement: adım 8, 2 resimden 2.
    • Lift the lower level Motherboard upward.
    • Remove the silicon pad above the buttons.
  9. ATT CL2940 Buttons and/or Keypad Replacement: adım 9, 2 resimden 1. ATT CL2940 Buttons and/or Keypad Replacement: adım 9, 2 resimden 2.
    • Push the Button Panel upward and pull it out.
    • Replace the entire Button Panel or a single defective button.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Charles Messmore
541 İtibar
5 adet Kılavuz yazıldı
Ekip
IUPUI, Team 1-1, Harley Spring 2016 IUPUI, Team 1-1, Harley Spring 2016 üyesi
IUPUI-HARLEY-S16S1G1
4 Üyeler
13 adet Kılavuz yazıldı
Bir Yorum
Great explanation! Where would you recommend buying replacement buttons for the phone? Thanks
Sean Richardson - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 462
