Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Remove five 9.5 mm Phillips #1 screws from the back panel of the phone.
Slide the metal spudger into the crack and continue around to the front panel of the phone.
Unscrew five 5.6 mm screws on top level, yellow motherboard.
Lift the top level Motherboard in order to get to the lower level Motherboard.
Unscrew the 5.6 mm screw on the clip behind the Screen as shown.
Unscrew five 5.6 mm screws on the lower level Motherboard.
Lift the lower level Motherboard upward.
Remove the silicon pad above the buttons.
Push the Button Panel upward and pull it out.
Replace the entire Button Panel or a single defective button.
2 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
Great explanation! Where would you recommend buying replacement buttons for the phone? Thanks
